View unanswered posts | View active topics It is currently August 2nd, 2025, 4:32 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 95, 96, 97, 98, 99, 100, 101 ... 400  Next
Chaque a son gout as they say......
February 6th, 2013, 11:45 pm
Used it for work again, but it cut out on the way home. It would just about idle but died with any throttle, turned out one of the electric fuel pumps wasn't working. Think it must have been a bad connection as it worked again after a little fiddling.
February 7th, 2013, 1:27 am
Haggis Muncher
Had at it with the wire brush & kurust. Created 5 new, rather significant holes :(
February 7th, 2013, 8:05 pm
Took it out of a crappy old garage and then drove it back into a totally renovated workshop. :D
Spent two days making up my new benches, side shelving and tidying everything up. Now I can start work on the Fourgonnette without falling over everywhere. I even got my new welder and had a go - chuffed to bits :P
February 7th, 2013, 8:14 pm
Isee you got your new (old style number plates) Did you use the company I told you about.
February 7th, 2013, 9:51 pm
Oh yeah - yes i did, thanks for that. They came quite qickly and look quite good I think.
Although i got the plate for the Solex from Motobecane, along with some other stuff.
February 7th, 2013, 10:09 pm
Haggis Muncher
Being depressed about not making firkin freezing, i attacked mines with a poly pad in an angle grinder. I now have much less rust, but mainly because i have much less metal than i used to.
Also discovered that the o/s/f corner of the van body is almost entirely filler... :roll:
February 8th, 2013, 5:57 pm
Finished work early so took youngest one for juice and coffee in favourite bar. On way home passing lorry turbo pipe blew off so went from around 46bhp to 29bhp in a blink of an eye. The word F--K came to mind. Luckily had enough momentum to pass him. Quick fix - just jubilee clip split.
February 8th, 2013, 6:02 pm
Pottered about with the dog in the back. Everything seems to be working fine at the moment. 8-)
February 8th, 2013, 7:25 pm
Although the pooch does that 'what have I done to deserve this?' look rather well sorted... ;)
February 8th, 2013, 8:14 pm
