Author |
Tripyrenees
 Re: Rene - The 1970 AZU AK250
I had wondered why there was a brand new driveshaft gater rolling around the cabin when I bought the car. When I took the wings off last night I realised why. This was the first major job to be done on my car by me.... so out with the Restoration book and into the barn. Attachment:
It went to plan perfectly even the bit where I un did the engine bolts and scooted it over a little to get the end of the driveshaft out. All greased up (mistake number one, filled up the inner driveshaft and then found out the inner would not go in all the way... found grease nipple to release the pressure) All done  Attachment:
Can anyone tell me what the little bracket to the left of the driveshaft is for, this side is empty, the other side has two perished rubber bungs.
_________________ https://www.facebook.com/GNGLuscan
January 12th, 2013, 4:10 pm |
2cvkeza
Joined: February 11th, 2010, 11:36 am Posts: 603 Location: Slovenia
It is for attach the inner front wing. This is old type bracket. New type is made from rubber. Small rubbers for old type is same as rubbers for front bumper (new type) ... https://www.citparts.at/en/products.php ... h&q=110012
_________________ www.2cvkeza.com
January 12th, 2013, 4:16 pm |
Tripyrenees
Thanks Keza.. So it must need the little rubber bungs then. Any idea where I can get them, just checked a few catalogues and found the bracket but no bungs.
I assume the front wing just sits inside these (I did not notice this when I removed them, don't think they were fitted properly)
January 12th, 2013, 4:24 pm |
2cvkeza
You can buy it from me or from Citparts.at (Austria). See link in previous post... or here ... https://www.citparts.at/en/products.php ... h&q=110012 ... Say... Keza told you
January 12th, 2013, 4:28 pm |
Is that madvice from the 'restoration' book? The usual method is to jack the chassis high enough for the suspension arm to be on 'full droop', turn the wheels towards the side on which you're working, then there should be no need for attacking the engine bolts. ken Tripyrenees wrote: It went to plan perfectly even the bit where I undid the engine bolts and scooted it over a little to get the end of the driveshaft out. All greased up (mistake number one, filled up the inner driveshaft and then found out the inner would not go in all the way... found grease nipple to release the pressure) All done  Can anyone tell me what the little bracket to the left of the driveshaft is for, this side is empty, the other side has two perished rubber bungs.
January 12th, 2013, 7:38 pm |
banjo
Joined: June 5th, 2009, 9:17 am Posts: 747 Location: Staffs & France
This must be about AJS bikes,I haven't seen the term Jampot which referred to the rather large round rear suspension units,for many a year
January 12th, 2013, 10:35 pm |
Tripyrenees
I have only got a little jack
January 12th, 2013, 10:44 pm |
ChrisW
Joined: February 21st, 2012, 9:01 pm Posts: 1136 Location: Avranches, Sud Manche, France
Did you ever get your Dynamo to work???
January 17th, 2013, 6:23 pm |
Tripyrenees
Not yet.... everything is prepared for the new dynamo. I have traced all the cables, tested them, rejoined them. Cleaned all the earths from chassis to battery. Put in a new Regulator 8325A. I paid for the new Dynamo 7276G over two weeks ago but the old French guy (ex citroen mechanic) waited ages for my cheque to cash then another age to post it. So I now have the tracking number and my nose pressed up against the window for the postwoman. It would all be so easy without the waiting.
January 22nd, 2013, 4:14 pm |
Tripyrenees
At last it arrived. The new dynamo which will solve all my charging problems... Brand new in the box Attachment:
Looks new and the only thing I noticed different to my existing unit is that the field terminals are connected one on the rear and one on the front of the new one where both field terminals were connected together on the rear of my old one. Attachment:
All fitted to the van and on with the test Attachment:
IT WORKS - hooray!!! The charging light on the dash board has gone out for the first time I have had the car. Everything seems to be working well and my lights a little brighter. It is now throwing down with rain and snow so do I go out for a test run...... I must.
January 23rd, 2013, 4:10 pm |
Users browsing this forum: No registered users and 21 guests |
