View unanswered posts | View active topics It is currently November 20th, 2025, 10:06 pm
 Waxoyl inside toe board void
Post Waxoyl inside toe board void
Hetty has a replacement toe board, I was thinking of cutting two small holes about 6" in from the sill to enable me to get wax into the void where they typically go.
Am I ok to do that? It won't weaken the structure?
January 11th, 2013, 1:28 pm
Post Re: Waxoyl inside toe board void
It may catch fire when being welded back up?
January 11th, 2013, 1:45 pm
Hopefully the waxoyl will negate the need for welding in the forseable future ;)
January 11th, 2013, 1:53 pm
Go for it Sam. Bore holes everywhere and use a spray nossle which spray in all directions. Sounds sexual. :mrgreen: Just plug the holes afterward with plastic plugs removeable for next time
January 11th, 2013, 2:03 pm
Haggis Muncher
I'm about to do the toe board on my van so i'd quite like to see how you get on, sam!
January 11th, 2013, 2:29 pm
I sprayed the inside of mine after all welding finished.
January 11th, 2013, 3:48 pm
Aka photos, photos, photos!
A point which I second :)
Overly Ambitious Project
January 11th, 2013, 3:58 pm
scared of the dark
The waxoyl 'kit' I have contains a long tube with a 360° sprayer on the end of it - would just need a single small hole in the middle as would reach all the way across.
When you've done yours, do mine please, I can't be arsed.
Some previous cars:
January 11th, 2013, 5:22 pm
If you've got one, use a compressor and schutz gun, rather than a hand-pump squirty. And don't confuse "waxoyl" the proprietary with the concept - there's much better out there.
http://rust.co.uk/ have a wide range of rustproofing wax.
January 11th, 2013, 6:19 pm
Indeed. It's not that good actually, it does rubbish in tests. Even Dinitrol makes it pale into insignificance, let alone the really good stuff.
January 11th, 2013, 9:43 pm
Users browsing this forum: No registered users and 18 guests
