View unanswered posts | View active topics It is currently November 19th, 2025, 11:59 pm
Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3, 4  Next
 To channel or not to channel thats the question........
Post Re: To channel or not to channel thats the question........
December 4th, 2012, 12:21 am
How low are you going?
The sills are normally around 6cm above the floor.. I made a straight line to the end of the sill so it about 7.5cm now.......
So the body is now lowered about this 7.5cm at the chassis, its (more then) enough for me......
may bee I lower the chassis also 4 or 5cm at the front mabee 10 or 12 at rear so total about
Total lowering 10/12cm at front 17/19 at rear........ Don't want troubles with heatblisters from tyres at fenders anyway...... so will see
December 4th, 2012, 12:27 am
today I did the floorboard but ran out of welding wire.............
made a cross-beam from a split 60*40mm 2mm thick
I always make triangle reinforcements where the body hits the chassis....
December 12th, 2012, 10:49 pm
Today bootfloor time..........
December 18th, 2012, 11:39 pm
Do you have twin brother? 1-2 spark - channeled 2cv - there must be 2 of you - very busy.... :)
December 19th, 2012, 9:14 am
Not to mention the DIY powder coating and DIY sandblasting booth...
December 19th, 2012, 10:46 am
and I'm doing only 1/4 as much as I want.. :lol: :lol: :lol:
honest...
1-2- spark is only making testdrives these days (driving from and to my work)
making only little adjustings at the circuit........
channeling is the hobby
powdercoating/sandblasting is my wifes son doing......... (I'm just supervising, (love to do that))....
December 19th, 2012, 1:26 pm
December 22nd, 2012, 8:41 pm
I'm having some days of (no not offdays), so could do some things to my turbo 2cv....
chopped the frontbench 4 cm.
chopped the steeringwheel holder.
have an ami 8 steering joint build in the steeringcolum????
sandblasted the seatsliders and mounted them.
chopped the frontfenders about 5cm.
chopped and readjusted the lightbar (didn't make pictures of it yet)
So now it looks like a 2cv again..
January 4th, 2013, 7:27 pm
This is a nice modification, it brings the angle of the wheel more vertical (also clearing away from the beer belly if its a problem!)
Yes, Steering column, I used one from the GS, where did you attach the spline? I but mine up high near the column bushes but I think on the end of the universal joint would be easier!
I guess you mean on the inside of the fenders to clear the chassis. I still need to modify the outer lip of mine as it rubs hard when the suspension bottoms out on them...
Not yet! you have to get rid of the Frankenstein air scoop and replace it with a neat little shaker hood!
I love your work Geo, real no bullshit practical fabrication.
keep it up.
PS. btw, what are the items in the pic of 2403 & 2401? new air scoop!?
January 6th, 2013, 2:50 am
