View unanswered posts | View active topics It is currently August 14th, 2025, 5:08 pm
Reply to topic  [ 417 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 42  Next
 1976 AZU250
Post Re: 1976 AZU250
Maybe someone fitted a long reach plug by mistake?
Whatever it was, there's no sign of erosion and not enough damage to affect how the piston rings will seal.
As for tidying up the bores, 'old school' style here... :lol:
http://www.youtube.com/watch?v=uJqMdZ2IB7s
p.s. @ Smiffy. I always leave that ring of carbon at the top of the barrel as it is.
banjo wrote:
The second piston shot looks like someone or something has dinked that edge of the piston it does look liked erosion as you can see the deformation in the machining lines below the mark.You might well get away with new rings and a hone of the bores, as long as there's no gouges in the barrel or piston skirts. However as Sean say's the cost of barrels and pistons is not that expensive around £190 which for peace of mind is money well spent.
Mind a set of rings at about £25 and a honing tool for about the same is a big saving if there's no damage as mentioned :-)
December 16th, 2012, 1:13 am
That is my opinion too.
The barrels do'nt look that bad, so maybe it is worth saving the old parts.
I don't think the "dent" will affect the reliability of the engine.
But the question remains: "In what condition ist the cranck?"
I am afraid you will have to split the engine completely, which I did and I really did not find it very hard to do, I kept "How to restore citroen 2CV " at hand to prevent to make a mistake.
It is like a cookbook ;)
December 16th, 2012, 9:26 am
Just split the case and had a look inside... when I looked inside it occured to me (duh!) that I hadn't got a clue what I was looking for!! I took some pics (I'll upload later) and everything looked fine to me, but I need some pointers from you experts with regard to the telltale signs of what constitutes a knackered crank.
December 16th, 2012, 8:23 pm
Count me out, I just did it once with the cookbook at hand :)
December 16th, 2012, 9:13 pm
B@gger,
if I'd noticed this earlier, I'd have advised against splitting the cases, as putting things back together correctly is always more difficult than pulling them apart.
A preliminary test of the crankshaft would have been to check for any 'in & out' play of the con rods, as it's invariably one of the big end bearings which fails first.
Mind you, now that it's apart you can do the definitive test which involves suspending the crankshaft in one hand and striking the top end of that con rod with a gloved hand.
If you hear a definite 'clack' noise, there's play in that rod's big end...
Also check the camshaft for wear on its lobes, most common on the ramps of the exhaust lobes for some reason.
December 16th, 2012, 9:43 pm
There's some good descriptions and pictures of how to check the crank in the technical forum, from when I was asking about it. My advice is don't check it, you might be disappointed.
December 17th, 2012, 12:15 am
ken wrote:
B@gger,
It is a chance to clean it all up 1
i was glad I did, because there was so much sludge in my engine and now I could clean it all.
You only should be carefull when putting everything together again.
December 17th, 2012, 8:36 am
Opening the engine case was an interesting and satisfying experience. After removing the various nuts and bolts, cracking it apart felt rather like separating the halves of a chocolate easter egg!
There was a load of sludge at the bottom, as I expected, which all cleared away after a quick dunk into a bath of petrol. Everything moved freely and I couldn't see anything horrid - although I'm going to have to go and look up the whereabouts of con rods, big end bearings, exhaust lobes and so on in order to know for sure.
Here's what I saw:
Putting the case back together was interesting. The crank wouldn't turn when I tried to tighten the case (the two halves were very reluctant to mate together), so I loosened everything off and will leave it with a slight gap for now.
December 17th, 2012, 11:00 am
No wonder I can't find any decent feckin' rear doors for my van, moan droan etc.
January 23rd, 2013, 6:36 pm
Got fed up with faffing about with a ropy 30-year-old toy welder (Clarke 100E), so I sold an asset or two and bought one of these!
March 12th, 2013, 6:27 pm
Users browsing this forum: No registered users and 13 guests
