View unanswered posts | View active topics It is currently June 19th, 2026, 7:13 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 15, 16, 17, 18, 19, 20, 21 ... 105  Next
 Make Your Own ....2CV.... 4x4
Brakes - Bleeding Brakes.
Have made brake "Line Lock" for both the front & rear, utilising the valves inside a BX ABS controller.
November 28th, 2012, 5:18 pm
did you solve the triggerwheel issue???
Looks like a Hightech 4x4 to me........
November 28th, 2012, 5:57 pm
@did you solve the triggerwheel issue???
Doing some research on Magnetic Reluctor Rings
@Looks like a Hightech 4x4 to me........
Some Electrical components but as yet No Electronics ;) .
November 29th, 2012, 12:50 pm
any progress here?
January 29th, 2013, 9:52 pm
Got all excited as I thought there was an update for this! :lol:
No rush... ;)
Overly Ambitious Project
January 29th, 2013, 10:07 pm
Slower in the winters months, but getting there,
To Do..fuel tank/pipe, all the wiring + dash, engine cover, passenger seat/base, front bump stops +++
For the keen DIY guys, an other forum https://www.dropbox.com/sh/2xt53owa49nbgqq/V6wonUmQ72.
January 29th, 2013, 10:20 pm
Oops http://forum.difflock.com/viewforum.php?f=73
January 29th, 2013, 10:26 pm
Unknown engine.
New plugs,oil.
Done tappets.
Ignition is 123 with good spark
Comperession (cold is < 90)
Home made exhaust?
WON'T start?
Any ideas
February 17th, 2013, 12:38 pm
Wet plugs - dry plugs?
Timing set correct?
Usual things
February 17th, 2013, 12:46 pm
Had plugs out, bit oily.
Is it likely to start with v.poor compression?
Cheers
Peter
February 17th, 2013, 12:58 pm
