View unanswered posts | View active topics It is currently November 20th, 2025, 7:21 pm
Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
 How do I know a crank is any good?
Post Re: How do I know a crank is any good?
Thanks all of you. Dead chicken analogy worked fine. I wonder if you hit a chicken like that what sound it makes?
Russel, dead chickens don't make any noise, they convulse??? a litle....
It's like a batteur, when you hit it the conrod goes down so fast and the crank stays in place so you feel/hear the play between them...
proposal for a new banner??
October 10th, 2012, 7:21 am
Thanks, it all makes sense. I just hope the crank is ok. I have been surprised by this engine, so far every nut and bolt has come undone with no problem. All the manifold nuts, the oil cooler, even the heads came off the barrels with no problem.
October 10th, 2012, 7:26 am
@ Russ if only it were thus - good unscrewing usually means most of the oil was on the outside and the internal stuff is a mess :cry: the orange ones engine was a rusty furry lump overlooked for years, mint 30k internals :D
@lpgo your English doesn't need translating from checking big end bearings to dead chicken - brilliant illustrates the method perfectly and i suspect that has now "Stuck":lol:
@ayjay yep rocking the flywheel will indicate if the mains are really really shot As the crank is supported at the front and the back by quite large bearings any lateral movement of the crank is minimal and throw in a small amount of end float its difficult to decide how much clonk is terminal. The "dead chicken" is to check the big ends. Main rear can be taken off and the journals inspected for scuffs and wear.
PShttp://dictionary.reference.com/browse/grammer you just keep setting yourself up ;) :lol:
October 10th, 2012, 9:05 am
Anyone else noticed that it always seems to be the offside bigend which fails first when an engine is starved of oil?
Mind you, if the driver's hearing aid has flat batteries, it has been known for forward progress to be maintained until all of the bearing material has been stripped from both big ends and distributed through the engine in tiny flakes ... :roll:
October 10th, 2012, 1:04 pm
It's all fucked.
October 10th, 2012, 8:41 pm
As per Seans prediction. Oil pump has scoring in it, the valves are ok although covered in gunge, the pistons are ruined, the exhaust tracts are full of some sort of mushy rust-like crumbs, the cam lobes appear to have worn through the hardening on the tops with evidence of pitting too. The combustion chamber is eroded too.
the crank makes a clack noise when I 'choke the chicken' and has around 1mm-1.5mm of play at the little ends which you can see if you click the photo of it (it should show a video)
It's all bollocks.
October 10th, 2012, 10:08 pm
if the grooves in the tops of the valves are still nicley rounded with no sharp edges then youve got a set of collets out of it, oh and some nuts and bolts every cloud eh?
thats the same sort of state the French engine I had been given was in it was one of the filterless cases -gold engine tag and 12mm headed M7 nuts and bolts, cases are the only thing that remain.
that must have been pinking like a jackhammer
October 10th, 2012, 10:42 pm
I've got another block with crank and cam in which has been sitting minus heads in the damp for the last 4 years, I'm sure it'll be fine, I'll open that up tomorrow.
October 10th, 2012, 11:01 pm
This one has died about 25 years ago I guess!!
The car has stood since 2003 and not run since then. I guess it's not seen much love before then either.
October 10th, 2012, 11:04 pm
