View unanswered posts | View active topics It is currently November 20th, 2025, 9:01 pm
 Carb return spring outer replacement
gym bunny
Post Re: Carb return spring outer replacement
wanted to take the whole end off to change the smaller router spring but little peened over end meant no go...
so i removed the little peened over end by filing it flat.
then nipped out for dinner
removed the end plate and fitted the new spring being careful to get it in the correct way first (few trial fits obviously!) then welded it back on
refitted to carb making sure that the spring end were in their correct places and under tension/sprung
refitted it to D*lly and after a bit of turning over re-fueling she fired into life and ran fine. Just need to extend the tie wrap from the headlamp bar as the spring is too tight making the throttle heavy!
tada! :shock:
1299cc FTW
September 4th, 2012, 9:05 pm
Nice work Tim, cracking pictures, nice and clear for simple folk like me 8-) can't believe it is that fiddly, looks like quick job at first glance. Going to have to borrow a dollop of weld from someplace.
Ben
September 4th, 2012, 9:15 pm
exellant tim, glad you found the best way to fix the prob, great weld too!
September 5th, 2012, 11:18 pm
Users browsing this forum: No registered users and 13 guests
