View unanswered posts | View active topics It is currently June 25th, 2025, 11:40 am
 a pathetic front window question
Post a pathetic front window question
when the front half window(accidentally) slams/swings closed, and shags the lip on the spring catch by bending it in a bit, :roll:
August 23rd, 2012, 11:50 pm
Post Re: a pathetic front window question
I don't understand?
August 24th, 2012, 12:03 am
Basically, out with the readies and buy a new catch....
August 24th, 2012, 12:18 am
I would advise removing the Offending clip and carefully bending it back to shape with Pliers.
or as I do just Hold the window against the clip every time you need to secure it, Making a mental note to "Sort it at the weekend" Forget and never get round to it :D
August 24th, 2012, 12:20 am
Just bend-out it back.
Actually I use to slam the window close,
while holding the catch closed
to bend-in the lip. :!:
I've Been Wrong Before.
August 24th, 2012, 1:07 pm
Actually, it is a bit of a bugger to get them set right. I've got new catches, and it's a swine adjusting them with the screws, and bending the metal with pliers to fit. And a few weeks later, it needs doing again!
August 24th, 2012, 7:44 pm
sorry if my message was a bit garbled!(its probably the same now :lol: )
(as jethro said) "what happened waas"- when the window is open, and i get out and close it(1) --it sometimes swings shut with a bang!, thus bending the tip of the lip on the spring catch-
i normally bend said lip back out using a 2p coin
apart from that everything good
(1) i cant fully close it from inside, as i cant pull the glass totally shut :roll:
August 24th, 2012, 10:58 pm
I have fixed a pair of stainless steel self adhesive hooks upside down just above the catches so I can pull the window shut one handed whilst driving..They can be seen in the attached picture :idea:
DSCF4340 by 2steamhorses(Bob), on Flickr
August 25th, 2012, 12:08 am
Now that's a damned good idea!
August 25th, 2012, 8:33 pm
exellant idea
mine had stick on suckers which pulled off of the glass
August 25th, 2012, 10:49 pm
