View unanswered posts | View active topics It is currently November 20th, 2025, 3:28 pm
Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 LNA - GS Gearbox's - Ventilated Discs - Oltcit/Axel
Post Re: Ventilated Discs - Oltcit/Axel
Here is the Lna gearbox mount I made.
just enough clearance for the sway bar...
harley
July 12th, 2012, 4:43 pm
Post Re: LNA - GS Gearbox's - Ventilated Discs - Oltcit/Axel
Where have my balls come from!?
I separated the LNA box to tap some threads out to m10, when I did so a ball bearing dropped out and I am not sure where it is from...
I know it must be from the selector fork but not sure where.
One goes in the channel on the top left of this pic with a spring and pin.
But I found another Ball on the Magnet amongst the oil sludge, not sure if it was already there as this box as definitely been reassembled in the past...
Here is the only wear I can seen.
Cheers,
July 15th, 2012, 9:18 am
Harley,
Haynes to the rescue, Page 62
July 15th, 2012, 9:38 am
Uuum, I got it back together... then found this on the floor...
Time take it apart again... don't ya luv that.
July 17th, 2012, 3:51 pm
Your are not alone, after the sixth time, you know where the bits go :)
July 17th, 2012, 6:06 pm
Bell housing cut to fit the disc rotors:
I luv what can be done with a grinder :twisted:
July 24th, 2012, 7:53 pm
I just tried starting the car, it turned over fine at first but after a couple of goes cranking it now makes a horrible grinding noise, new Valeo starter. I fitted the old starter and the smae thing, first few cranks where fine but now it grinds... Looks like the starter gear is not throwing in deep enough. Any ideas?
Cheers
July 30th, 2012, 7:51 pm
maybee 2cv starterengine and visa flywheel or visa starterengine and 2cv flywheel????
visa 131 tooth / 2cv 107 tooth
July 30th, 2012, 9:53 pm
It is the same flywheel and starter from when it was my daily driver 3yrs ago.
The new and old starter also have the same tooth count.
Cheers
July 31st, 2012, 1:50 am
Harley,
Is the pinion being pushed to far?
I was told, You need a "spacer"?,
But havent tried my set up ,
July 31st, 2012, 10:00 am
