View unanswered posts | View active topics It is currently November 20th, 2025, 9:01 pm
Reply to topic  [ 5 posts ]
 435 cc Oil Leak - Is this a common problem
Post 435 cc Oil Leak - Is this a common problem
When the engine is running I have a single drip of oil about every ten seconds from (i think)where the gearbox joins the engine. Has anyone got an idea of what this could be ? and what is involved with the repair. Many thanks.
July 8th, 2012, 5:23 pm
Post Re: 435 cc Oil Leak - Is this a common problem
Sounds like crankshaft rear main oil seal, although I'm not sure whether there is an actual lip seal there or just an oil return scroll on the crank. Either way it's an engine out job.
Brooky.
www.stockwell-lodge.co.uk
July 8th, 2012, 7:04 pm
engine out and flywheel off so not really an easy fix whatever it is
should be a seal on the crank if its an engine that has been stood the old oil may have pitted the surface, the oil pump is also in that area so may be worth checking its not from there.
July 9th, 2012, 12:15 pm
Any oil in the air filter housing?
Do an oil breather test including compression test before pulling the engine out.
Replacing seals may not be enough
July 9th, 2012, 12:24 pm
check the oil level, just in case its overfilled
July 9th, 2012, 2:22 pm
Users browsing this forum: No registered users and 13 guests
