View unanswered posts | View active topics It is currently February 3rd, 2026, 5:04 pm
 Snowy the Snail
Post Re: Snowy the Snail
Not sure on oil Change times for the gear box, but I did mine recently, how rank it was was un believable!
It was easier to change gear afterwards too!
November 29th, 2011, 9:30 am
April 24th, 2012, 1:09 pm
Big weekend for Snowy: front and centre to transport my brother to church for his wedding.Image
May 28th, 2012, 4:21 pm
Is there an easy fix for this pesky problem, or will I have to find a new window?
June 26th, 2012, 10:14 pm
Define 'easy'...
I've had that happen before, I just welded it back on. If you don't have that luxury then I reckon it'd be easier to just change the window. Do you have a spare, or would you like me to post you one?
June 26th, 2012, 10:25 pm
My passenger window went in Belgium on the way home from Spa a couple of years ago - I ended up folding the passenger door mirror in to hold the window closed - that was an easy fix! :lol: It was like that for nearly 12 months until I dug a spare frame out of the shed & transferred the glass & rubber over! :)
June 26th, 2012, 10:28 pm
Define 'easy'...
I probably have a spare knocking around somewhere in my dad's garage, thanks Russ. I'll have a look at the weekend. Until then Neil's crafty mirror fix will do the trick.
Might even have a go at fixing it, once I get my rediscovered welding kit up and running...
June 27th, 2012, 12:15 am
My preferred method...
June 27th, 2012, 12:39 am
How we fixed it for James :
Unfortunately, James thought our repair was sub-standard and still moans about it to this day.
June 28th, 2012, 8:19 am
An impressively elegant solution. Can't see why James would find fault with it.
June 28th, 2012, 9:08 am
Users browsing this forum: No registered users and 773 guests
