View unanswered posts | View active topics It is currently August 14th, 2025, 6:17 pm
Reply to topic  [ 538 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28 ... 54  Next
 Joolz's Red One
Post Re: Joolz's Red One
Thanks for the Info Joolz.
Yes I agree that the Poly Urethane would be to hard. I can't get the same transit mount here in Oz easily so I ordered some off Ebay, cheap! Is this the ones you used?
Is it not a concern that the gearbox could slide forward or backward out of your mounts? Only if the front mounts failed I suspect.
If you have the time to send me the width of the bush, inner shaft, that would be helpful to design my mounts. Here is my idea, maybe overkill, I will reduce it a bit I think...
The white spacers on the back are because the LNa end plate is not flat, the curved is the original mounting support.
June 19th, 2012, 11:48 am
Yep, those are the ones, cheap as in the UK but your postage bumps it up a little.
No I'm not too concerned about them moving, if I see any sign of it, a blob of weld will sort them.
I don't think your bracket looks overly heavy if you're making it from 4 or 5mm plate, and it will allow plenty of rotational movement, assuming you're keeping the original front mounts. I'll get you all the dimensions later today.
June 19th, 2012, 12:13 pm
I couldn't find my other set of bushes so did my best to measure the ones on the car, was a bit awkward so I may be a mm out. Should be close enough to finish the design, but maybe don't cut anything yet.
Your CAD is all very pretty, but paper and a biro is more how I roll. :lol:
June 20th, 2012, 12:14 am
Champion Joolz, thank you.
What is your profession by the way?
June 20th, 2012, 12:21 pm
I'm a welder and fabricator, making crap like this,
https://fbcdn-sphotos-b-a.akamaihd.net/ ... 7357_n.jpg
June 20th, 2012, 10:56 pm
http://a2.sphotos.ak.fbcdn.net/hphotos- ... 7357_n.jpg
:shock: Holy crap, make some for a 2cv! :lol:
Nice work.
June 21st, 2012, 2:13 am
Those are nice ... I wish I could do that. 8-) What are they for?
June 21st, 2012, 5:32 am
VW based buggy?
June 21st, 2012, 8:27 am
1 point to Lenny! https://fbcdn-sphotos-g-a.akamaihd.net/ ... 9514_n.jpg
June 21st, 2012, 11:49 am
I did some fuel consumption calculations for the first time with the 5-sp gearbox. When driven sensibly over a long journey it'll do 45mpg. I can't remember now what it used to do with the old box, but I'm sure this is an improvement.
June 25th, 2012, 2:51 am
