View unanswered posts | View active topics It is currently November 21st, 2025, 12:18 am
Reply to topic  [ 6 posts ]
 1299cc Pinking
gym bunny
Post 1299cc Pinking
Under load or low revs 5th gear pinking is very noticeable.
Any ideas whats causing it or where to start looking? Should i avoid cheap ASDA fuel (129.9 / litre)
Cheers
Tim
1299cc FTW
June 18th, 2012, 8:06 pm
Post Re: 1299cc Pinking
Tim,
assuming the timing is set correctly in the first instance, might be worth checking whether the vacuum advance/retard is working OK.
There should be a small bore vacuum pipe connected between the carburettor and the distributor.
Cheers
Tim
June 18th, 2012, 8:16 pm
£1.29 a litre? You can't buy water down here for that!
June 18th, 2012, 8:37 pm
I think you have conterweights, try to back up them a little (bend them) so you have less advance.
I hope you know what I mean.... otherwise I try to explain it better........
June 18th, 2012, 9:58 pm
Russ the fuel station near me = 129.9 petrol 133.9 diesel
June 19th, 2012, 12:16 am
gym bunny
Need to unpack my timing gun then and have a check. As for the little vacuum pipe, I have just checked and it is there and appears in good condition, even the rubber end sleeves!
1299cc FTW
June 19th, 2012, 7:56 am
