View unanswered posts | View active topics It is currently June 26th, 2025, 4:53 am
Reply to topic  [ 3 posts ]
 wheel hole dimensions
Post wheel hole dimensions
Hi guys,
does anyone have the measurements for the distance/angle between the wheel stud? If so would you be so kind to tell me what they are.
Thanks
June 17th, 2012, 11:17 pm
Post Re: wheel hole dimensions
jack,
the correct term is pitch circle diameter (pcd), which is 160mm for A series wheels.
Since there are 3 studs, their separation is 120 degrees.
If you're looking for alternative wheel rims, the offset of the rim also has to be taken into account.
jack_dyane wrote:
Hi guys,
Thanks
June 17th, 2012, 11:35 pm
Thank you, not really after alternative wheels, just making a rear hub/drum puller as mine isn't wanting to come off.
June 18th, 2012, 7:46 pm
