View unanswered posts | View active topics It is currently August 6th, 2025, 12:23 pm
Reply to topic  [ 5655 posts ]  Go to page Previous  1 ... 342, 343, 344, 345, 346, 347, 348 ... 566  Next
 The O/T thread!
Post Re: The O/T thread!
wow
http://www.urbandictionary.com/define.p ... 20Cylinder
June 12th, 2012, 9:35 pm
:lol:
That's how we roll!
June 12th, 2012, 9:39 pm
That's a recipe for a knackered coil, surely.
June 13th, 2012, 12:38 am
Surely that should be V twin
June 13th, 2012, 2:15 am
Does anyone know anything about 12v eletric timers?
I'm after a timer switch to operate at set times for a set time,
It is for my 12v 600w inverter. So needs to be up to the job
Or a small one with big relay..??
Ive looked around and don't really understand it
I don't want to leave my inverter running 24/7 as I geuss that's not good for it and it will flatten battery
Oh Its a skytronic 600w (decent brand)
June 13th, 2012, 11:50 pm
I'll answer this on the grounds that for once I can understand what you're talking about, well done!
I don't know anything about 12v timers but the most readily available timers are probably the ones that plug into a 13amp socket Image
They also come in digital, and I'm sure they could be cannibalised for many applications. They're designed for at least 13amps, not sure what your inverter draws could be 50amps (600w/12v = 50amps, but checking the spec is your job) so you could still need a relay. What are you planning on running off it? A 50amp drain will still flatten your battery in under an hour.
June 14th, 2012, 12:50 am
Planning on running a de hunidifier in my lockup. Maybe damp soaking bags might be better
June 14th, 2012, 2:15 am
What's the general current concensus on Mazda mx5s? Are they still, as they always were, a hairdressers car that really made a bold statement about a man if he drove one, or are they past that now? It's just about the only rwd car you can buy nowadays for under £500. In fact they are ridiculously cheap at the moment and I though maybe once my 2cv has sold and I have a spare space in the barn I might pick one up for a bit of fun. But I don't want to if bigger boys will laugh at me.
June 14th, 2012, 7:33 am
There ok. My brother was going to buy ond
June 14th, 2012, 8:07 am
