View unanswered posts | View active topics It is currently November 20th, 2025, 3:46 pm
Reply to topic  [ 284 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 29  Next
 LGY 275P Rises Again!
Post Re: LGY 275P Rises Again!
Ok the saga continues.....
Had all day on it 2day, with 2 engineers, got a bit done but as always one job always takes so much longer as that leads to another job, then you have to get that sorted before u can carry on what ya doing, you'll all know what I am on about, Well the pics basically say what we have been up to...
File comment: Still loads to do, as I'm not just going to get it roadworthy and Mot it, will spend a bit more time and get everything done before it hits the road..
File comment: Back home on the drive 2nite...
File comment: Still need to weld in new metal on bulkhead for the accelarator cable as it looks a bit tasty!!!
File comment: Got some Bx seats in...
File comment: new brace across the middle, will support a bit more bracing going on bulkhead later.. and the standard one was fouling the gear change!!!!!
File comment: its getting there, new brass pin to be fitted and finish welding and tidying it up!!
File comment: should be able to make out what it is and where it goes
File comment: new aluminium spacers, found 2 M8 holes in the chassis which were ideal to mount a wing support off the headlight bowl as on a dyane...work out quite well..
File comment: Trying to fix the bonnet pins, what a twat...ending up finding a load of rot and having to cut out and weld in new metal!! Eventually got the pins out of bonnet after some heat as you can see from the paint on the bonnet, but at least that are out and now it open up properly!!
Dyane 12 1976 (ish)
May 26th, 2012, 9:28 pm
Nice to see it's coming along :) . Bon courage, as they say.
May 26th, 2012, 10:25 pm
Love it! Stick with it, Matt. So few sidewinders left now & this is destined to be one of the best!
May 27th, 2012, 12:42 am
Thanks fellas, not sure about that neil, but it might look ok when done... :P
You are probably a good one to ask neil, Do u know how many Sidewinders (dyane based Particularly) there are in the country??
Can't be more than a handful :?: :?:
Dyane 12 1976 (ish)
May 27th, 2012, 10:51 am
There used to be a nice one in metallic blue, owned by Emma Jenkins' (daughter of Dave and Kate) then-boyfriend Adam. This was back in the mid - 1990s, so whether it's still around or not I have no idea.
May 27th, 2012, 12:18 pm
So anyone know how many Dyane sidewinders are around and about in the uk then :?: :?:
James got the wiring loom cheers mate, will be putting it to good use 2moro when we go for round 2 on the beast..
Got most of the day on it again with my new found engineer friends!!!
Got the inlet manifold to sort, the new loom to make, fab some new metal for where the accelerator cable go through bulk head and no doubt we'll find a load of other problems along the way......... :roll:
More updates and pics to follow....
Dyane 12 1976 (ish)
June 6th, 2012, 12:16 am
Managed to get another day, well I mianly stood and watched whilst me fellas did the work!!
Anyway, only a couple of pics as they started fiddling with the wiring, and a lot of head scratching then presuaded... then we had to leave!!!!
File comment: Back home in the garage!!
Dyane 12 1976 (ish)
June 8th, 2012, 9:39 pm
I've hit a bit of a bad financial position just recently So.....
Does anyone fancy Finishing this off??
Any sensible offers considered!!
Please PM if you are interested...Cheers Matt
Dyane 12 1976 (ish)
June 22nd, 2012, 5:34 pm
:cry:
June 22nd, 2012, 6:15 pm
can't we start a fund :idea: ..... your so far now :o :o
June 22nd, 2012, 8:15 pm
