samfieldhouse
 Re: Belgian built 1969 AK350 'Hetty'
No it's fine I've brought her home as I have the spare feedpipes here, i'll sort it out monday/tuesday. Cheers though. Any change I can borrow your strobe next week?
| June 3rd, 2012, 12:00 pm |
Russell
You're more than welcome to, but it's locked in the workshop and I won't be there until Wednesday, although if you're desperate I could swing by Tuesday at some point. Your wheels should be done on Thursday, if I can I'll go and get them before work.
| June 3rd, 2012, 12:04 pm |
J-dub
I can bring a strobe Tomarrow
| June 3rd, 2012, 5:25 pm |
toomany2cvs
samfieldhouse wrote: While I did this and cleaned all the parts that Peter asked me to clean, he reassembled the box and sorted the brakes out as one side had the wrong size cylinder fitted. <coughs, shuffles feet> I fitted those front cylinders. I didn't compare them against each other, 'tis true - they were bought as a pair, and in boxes that were marked up the same. Honest! samfieldhouse wrote: Just broken an oil feed pipe... Yeh, I fitted those, too - when the (repaired) ones that were on broke at the Dutch WM. Het obviously has a thing for being centre of attention at big camps. Quote: Might also fit my recon oil cooler too. Same banjo bolts for the head feeds as the cooler on those oldie motors, so it's only the cooler support that you'd need to undo on top. Daft not to. (But I never took the lid off the gearbox. Honestly. I didn't. There'll be an invoice in the folder from whoever did rebuild it, though.)
| June 4th, 2012, 9:45 pm |
Adrian, I wouldn't worry about it, as I reckon that fatigue failure of the differential shaft on Hetty was initiated a very long time ago, possibly by the shock loading which required replacement of the first/reverse pinion. Given that a gearbox is a 'torque multiplication' mechanism, the load which broke a tooth ( or teeth? ) on the first/reverse pinion would have been increased by a factor of over 20 by the time it reached the differential shaft. That could have been enough to induce the cracks which have since spread with use, resulting in failure when Sam administered the coup de grace when setting off at a T junction. If you look at Sam's photograph of the broken shaft, you can see that the outer edges of the shaft had given up some time ago, with the core left to struggle on for as long as it could. It's not a unique event, here's an input shaft which went the same way, although I understand that wheelspins from the traffic lights in first gear were involved with this poor thing... ken Gearbox (no)input shaft by slcchassis, on Flickr toomany2cvs wrote: (But I never took the lid off the gearbox. Honestly. I didn't. There'll be an invoice in the folder from whoever did rebuild it, though.)
| June 4th, 2012, 11:04 pm |
samfieldhouse
Just taken the fan off and confirmed that right hand oil feed pipe/banjo assembly is dripping so will get it sorted tomorrow.
Interesting that pic Ken, and again, I'm glad that it wasn't me that caused the problem!
| June 4th, 2012, 11:36 pm |
samfieldhouse
| June 6th, 2012, 11:57 pm |
toomany2cvs
samfieldhouse wrote: So the right hand accouterments were looking distinctly oily. LH last time, IIRC. So at least there's no real pattern... They're just shite, rather than there being a prob with one side or the other. The one that went before had been previously brazed back together. I assumed it was a poor quality fix - these ones hadn't been touched before.
| June 7th, 2012, 12:08 am |
samfieldhouse
I changed them back in September after the right hand one split on the way back from the Van camp. Thing is, I replaced them with 40 year old okish looking ones, least these are new and solid so hopefully ok
| June 7th, 2012, 12:12 am |
toomany2cvs
samfieldhouse wrote: I changed them back in September Oh, cool. I can go back to the usual "Blame the last bodge-monkey to touch it", then.
| June 7th, 2012, 12:20 am |
Users browsing this forum: No registered users and 278 guests |
