View unanswered posts | View active topics It is currently August 31st, 2025, 6:05 am
 60mph+ left hand vibrations?
Post 60mph+ left hand vibrations?
So I'm on a dual carriage way and doing 60 or 70 is on a long sweeping left hander and the steering wheel starts to vibrate like fuck, it's like driving down a cobbled street, reckon it needs a new rack rod end lever arm?
June 3rd, 2012, 12:07 am
Post Re: 60mph+ left hand vibrations?
Ours did that. A new kingpin cured it.
John Jordan
June 3rd, 2012, 12:08 am
Kingpin appears to be fine, as it should be only changed 3-4000 miles ago.
June 3rd, 2012, 1:02 am
Wheel bearing?
June 3rd, 2012, 1:19 pm
will that be evident when I jack it up? I believe that was changed at the same time as king pins.
June 3rd, 2012, 1:23 pm
if you jack it up and hold the wheel at something like 10 past seven and give it a good old wobble you should be able to see if something is amiss....
June 3rd, 2012, 1:28 pm
Ok will jack it up and grease everything on Tuesday, I guess then we'll see what it is.
June 3rd, 2012, 1:34 pm
Does sound a similar noise on my old white 2cv, in which I replaced king pins (still there), then control arms (a little better) then had the rack reconditioned. There is a little bush inside that wears out and can cause clonking, but I don't recall if that's shown n long curves. I'm thinking first check the lever arms.
June 3rd, 2012, 2:00 pm
See here.....Identical problem....
viewtopic.php?f=7&t=3550
Sean replaced kingpin, good s/h steering arm, and accurately adjusted track rod end, problem solved
June 3rd, 2012, 3:01 pm
No play whatsoever at all NON in either of the wheels when jacked up, so does that point to track rod lever arm?
June 5th, 2012, 6:58 pm
