View unanswered posts | View active topics It is currently June 27th, 2025, 5:12 am
 A strange thing
Post A strange thing
I have noticed a strange thing happening on my car.I have been driving it everyday for the last 12months,so I know all its rattles and creaks,but this has me beaten.
It has developed what I would describe as "steering shimmer",or wobble of the steering wheel when I go over a small bump or if the road is un even or rutted.The steering wheel seems to wobble so to speak,and the car seems to do the same.
The strange thing is,it only does this when I have the roof rolled back :o .I have travelled down a certain road with the roof back and it does it,and tonight I went along the same road with the roof closed and it was fine.
Any thoughts?
May 28th, 2012, 10:46 pm
Post Re: A strange thing
Those symptoms would sound like worn king pins or track rod ends to me and the fact the roof is open may just be coincidence?
May 28th, 2012, 10:52 pm
The BB does something similar - its just passed its mot with flying colours but I'm wondering could the front shockers be buggered?
May 28th, 2012, 11:05 pm
I had the same symptom, except the roof diversion
and it stoped when I changed the very worn track rod ends
and the rubber block.
I've Been Wrong Before.
May 29th, 2012, 8:10 am
New shocks fitted 12 months ago,new king pins recently,track rod ends ok,sterring arm ball ends ok,new driveshafts fitted before we went to France.
May 29th, 2012, 8:20 am
I suggest to open the track rod end housing and check the balls.
You may be surprised.
Do not rely on the play feel test.
May 29th, 2012, 8:27 am
A shimmer after hitting a pothole always points to track rod end balls in my experience.
May 29th, 2012, 8:38 am
I agree with you all,and will double check the ball ends,but,as I said,it only does it when the roof is open.When its closed,the car is 100% perfect :?
May 29th, 2012, 9:16 am
I found this out the hard way in my first 2CV. Not a pleasant experience! The funny thing, Dave, was that the problem did not necessarily occur every time... so there was me trying to work out what was happening, checking this, tightening that, until one day the track rod broke off at 60mph when I went over a bump. An alarming experience, to say the least, and one that could have been a lot worse!
May 29th, 2012, 10:22 am
take the track rod end housing apart with the special tool, mine were totally knackered /dry and one cup was broken in half with its other half missing! the arm ball ends were worn beyond recognition
it wasn,t mentioned in the mot whilst like this!!
June 3rd, 2012, 5:51 pm
