View unanswered posts | View active topics It is currently June 19th, 2026, 12:03 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
That looks amazing
So in theory you could set a limiter at 3000 rpm for economy ;)
May 21st, 2012, 11:12 pm
Post Re: 1-2-spark
Yes you can.... but not recommended. You can put an Visa vacuum box in it so when you run economicly?!?! the ledlight turns on meaning you are driving economic at the moment.
B.T.W first time I programmed the revlimiter at 1000 rpm. The next morning I was wondering why the engine didn't rev........ :lol: :lol: :lol: :lol: :lol: :lol: :lol:
May 21st, 2012, 11:16 pm
Post Re: 1-2-spark
:lol:
May 21st, 2012, 11:25 pm
Post Re: 1-2-spark
just got back from a week of holidays, and many things hapend in the mean time :)
I get an error when I start the program:
Fehler beim öffnen von COM1
it is quite a new PC I have here running on win7; 64bit. maybe that is the problem...
greetzzzzzzzzzzzzzzz
bitten by the Citobug...
May 22nd, 2012, 9:02 am
Post Re: 1-2-spark
Nothing to worry about, the only thing is , my software is searching for an 9 pin rs232 connection at your computer, but newer computers don't have them, all you need to do is to
take an usbport to rs232 convertor-cable and a litle software programm which makes a virtual comport and all will be fine.... Mark 4x4 has the same problem, so I orderded such a cable and it works fine.
Getting the eror means the software works......... sounds stupid I now..... will make a little
reprogramming and zip it here 1 of these days.....
BTW still waiting for the pcb's to arive.... (i'm going crazy Marks will picjup a set at the 2. of June.....)
Software runs almost bugfree now, can adjust dwell and revlimiter, advance is still a littlebit tricky but soon it will work also.............
May 23rd, 2012, 12:17 am
Post Re: 1-2-spark
Sounds like it is progressing nicely Lpgo.
Thinking ahead, RE: sequential ignition...
If you made a trigger wheel, say 36-1, that mounted where the advance weights sit, then using the points box mounting holes, mount a VR sensor to read it. Would this give enough information for sequential ignition or do you also need the crank angle?
May 23rd, 2012, 5:16 am
Post Re: 1-2-spark
This all looks great. My laptop runs XP so hopefully the RS232 cable will work on that.
Looking forward to having a go and testing this.
May 23rd, 2012, 10:29 am
Post Re: 1-2-spark
Today the PCB's arrived, but I decided to programm my software, it (almost) does what I want now and not what it will!!! To programm software takes you an hour or so, to make it foolproof takes forever (sorry guys nothing personal)!!
Here some pics of today!!
May 23rd, 2012, 11:24 pm
Post Re: 1-2-spark
Sorry Harley was forgotten to answer you.........
Yes you are right, you can do it this way, but not with my unit, it only needs 1 tooth like the visa engine. I haven't programmed it for 36 tooth. One tooth is enough to spark a 2cv (infact all 1 or 2 cilinder (boxerengine's)) with the sensor mounted at 45 degrees tdc. at the crankshaft. it is more aqurate
then a 36 toothwheel with Megasquirt (believe me I've got experience)
Citroen did a very good job making the Visa ignition back in the '70.
As I told before I'm going to use the original ignition from camshaft to make sequantial ignition, just sand 1 side down and the breakerpoints wil give 1 pulse every 2 crankshaft revolutions thus giving seqyuential ignition. No current is needed on the breakerpoints so they will last forever. I hope you understand what I'm writing otherwise I will here from you..
May 24th, 2012, 12:37 pm
Post Re: 1-2-spark
You mean, this will only give a pulse which will give information about which cylinder needs to be fired next? You know that the bit of points that slides on the camshaft will wear, too?
Isn't it easier to use a magnet in the way that 123 ignition does, but just 1 instead of 2 to "tell" a sensor when just one particular cylinder will fire/has just fired and to fire on the other one in the next cycle?
And I think sequential ignition is not about firing a spark every other revolution (instead of every time like in a 2CV), but giving a few sparks with varying timing for 1 cycle (some or maybe many modern cars do that). But what You're talking about should improve coil charging on high revs.
May 25th, 2012, 12:08 am
Users browsing this forum: No registered users and 204 guests
