View unanswered posts | View active topics It is currently February 4th, 2026, 1:42 am
Reply to topic  [ 438 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40, 41, 42 ... 44  Next
 1988 2cv D*lly bits and bobs
Post Re: 1988 2cv D*lly bits and bobs
.......or better still, Velcro the amount of times you remove it. ;)
:lol:
May 18th, 2012, 7:10 am
Coat 3 (or is it 4..?)
I'm not convinced brushing waxoyl on is the best way..
Takes 48 hours just to go tacky!! :shock:
Don't know if it's the lack of mixing (well shaking) the can, and me getting the thinner stuff on top..?
I gave the can a mass shake after it had warmed up...
Amazing how far a little bit of waxoyl goes
I'm not sure if I'm applying much at all by brushing. But spraying is out of the question completely
Oh well whatever
A few pointless pics (looks just the same.!)
I've no idea if anyone is interested in reading my, perhaps boring fettling, but anyway there you go !!
May 20th, 2012, 12:06 am
Waxoyl underseal which is what you are using doesn't dry. I've used it and don't like it for that reason.
The underseal version is not to be confused with original Waxoyl which is a cavity wax/oil.
John Jordan
May 20th, 2012, 12:20 am
I know it doesn't dry, but it was as wet as I'd painted if on after 24 hours.
I'm sure it'll be fine
I rAte waxoyl after seeing how well my car lasted underneath
May 20th, 2012, 12:24 am
Errr,
that's the whole point, isn't it?
Underseal which dries tend to be brittle, with cracks forming and corrosion occurring beneath the hardened 'crust'.
Rather like 2 pack paint which has been applied with inadequate preparation, come to think of it. :roll:
( Back in the day when I had a 'proper' job, I recall grease paint being used on the inside of box girder bridges, with one of its principal advantages being its resistance to drying out.
http://www.marineandprotectivecoatings. ... Finish.pdf .)
May 20th, 2012, 2:43 am
that black waxoyle is the best far better than the old pitch and sand stuff that trapped water underneath
May 20th, 2012, 7:00 am
You know that stuff catches fire like nothing you've ever seen before? It's going to make Gary's work of welding your floors in a bit of a challenge.
May 20th, 2012, 7:42 am
That's why I'm not plastering the floors and such.
Edit
I see what you actually mean
On sure it'll be ok. !
May 20th, 2012, 7:58 am
Your posts are always good reading James,just keep em coming :P .
Whos cara?
May 20th, 2012, 8:46 am
Thanks dave :)
I wish the waxoyl looked as smooth in real life. But I geuss my pound land paintbrush (pack of 6) isn't really helping
But nor am I buying a Harris brush !!!
May 20th, 2012, 8:53 am
Users browsing this forum: No registered users and 420 guests
