View unanswered posts | View active topics It is currently August 25th, 2025, 7:01 am
 Tracking ?
Post Tracking ?
The tracking on my D*lly is out a bit,steering wheel is not lined up properly and pulls slightly to one side on a straight road,phoned up local kwik fit and lad didnt know what a 2cv was,just wondering if best to take to a citroen specialist or try else where, :?
May 19th, 2012, 10:42 am
Post Re: Tracking ?
There are a few tracking threads on here that I found using the search facility...
viewtopic.php?f=7&t=1726&hilit=tracking
viewtopic.php?f=7&t=2236&hilit=tracking
viewtopic.php?f=7&t=3840&p=80211&hilit=tracking#p80211
May 19th, 2012, 10:53 am
Post Re: Tracking ?
pulling to one side isnt usually tracking
as the steering is self centring then they align themselves make sure that the rack is centred before you embark on any adjustments irrespective of steering wheel position
the one side thing will be kingpin wheelbearing or bent arm
May 19th, 2012, 2:58 pm
Post Re: Tracking ?
Thanks for replies,i think i made this sound worse than what it is,the steering wheel is only slightly out,but enough to notice,it doesnt pull vigerously to one side but if you take your hands off the wheel it will go to the left after a while,dont think its far out :)
May 19th, 2012, 3:30 pm
Post Re: Tracking ?
My steering wheel is just off centre I moved the shaft round one spline and it was out the opposite way,so I just don't ignore it.If I take my hands off she runs dead straight with no shimmy on a flat road,but will run down the camber after a while,which is to be expected. :|
May 19th, 2012, 4:24 pm
Post Re: Tracking ?
My wheel isnt straight when i go straight
When i put the shell back on ill try it on the next spline round
May 19th, 2012, 4:53 pm
Post Re: Tracking ?
probably just falling off the camber adopt the "elbow out the window one handed steer" position
May 19th, 2012, 5:02 pm
Post Re: Tracking ?
James,
try driving it _ before_ fitting the clamp, makes it easy to find the position where the wheel is closest to central.
Only on private land, of course... ;)
May 19th, 2012, 5:08 pm
Post Re: Tracking ?
Doh! :x
y'lern something new ev'ry day
May 19th, 2012, 5:13 pm
Post Re: Tracking ?
Sean wrote:
Doh! :x
And the steering lock!!
(or shouldn't I bother??)
May 19th, 2012, 6:45 pm
