Chris2cv
Joined: November 2nd, 2011, 12:35 pm Posts: 586 Location: Charente-Maritime
 Oil filter remover
Rather than hammer a screwdriver through the old filter (a practice I detest and one that I have never actually used anyway!), I turned up this correctly sized remover on Fleabay: http://www.ebay.co.uk/itm/180610505741Uses 3/8 drive or 21mm spanner and fits the filter perfectly:
| May 4th, 2012, 2:29 pm |
samfieldhouse
 Re: Oil filter remover
I use this:
| May 4th, 2012, 6:12 pm |
Chris2cv
Got a tub myself. On a shelf next to buckets of steam, boxes of glass nails, tins of Tartan paint and a bag of Tads lol.
| May 4th, 2012, 6:47 pm |
knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
Don't forget the rubber rivets to go with the rubber mallet. And don't forget the long weight which is in the stores.
_________________ John Jordan
| May 4th, 2012, 9:19 pm |
Taskos
Joined: February 22nd, 2012, 10:34 am Posts: 420 Location: Greece
Is it universal fitting or just for Purflux?
| May 4th, 2012, 10:08 pm |
Chris2cv
Taskos wrote: Is it universal fitting or just for Purflux? Any 76m 12 flute oil filter I would imagine, not necessarily Purflux.
| May 4th, 2012, 11:18 pm |
toomany2cvs
Chris2cv wrote: Taskos wrote: Is it universal fitting or just for Purflux? Any 76m 12 flute oil filter I would imagine, not necessarily Purflux. Which is great, until you need to remove one that's a different size or has different flutes. I like the chain or strap wrenchs, if you've got decent end access - or, if side access is possible, filter pliers really are the dog's...
| May 9th, 2012, 4:18 pm |
ben
I bought an old 2cv purflux made oil filter ring tool off ebay ,luck would have it it also fits BX and Xantia filters  Needed to be a bit of a contortionist on the Xantia though
| May 9th, 2012, 4:52 pm |
banjo
Joined: June 5th, 2009, 9:17 am Posts: 747 Location: Staffs & France
Which ever method you use it's only hand tight on fitting, I recall some idiots on BMW bikes used the fluted tool to do them up aarrghh! Also the original filter for the early 'K' flying brick had a nut welded on to assist removal. This was discontinued after being used to tighten the filters up by some workshops.
| May 9th, 2012, 6:17 pm |
Taskos
Banjo is absolutelly right. By no means do not tight any ,2cv, Xantia, Bx, etc by any tool! Only hand tight after applying some oil to the rubber gasket.
| May 9th, 2012, 6:39 pm |
Users browsing this forum: No registered users and 4 guests |
