View unanswered posts | View active topics It is currently June 19th, 2026, 5:28 pm
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 105  Next
 Make Your Own ....2CV.... 4x4
The design is more work than the the bolt thru, but I reckon its far easier to line up when refitting the engine.
@Joolz
Bush is from Cit - C15 & Visa or Pug - 205 ......Track control arm, inner bush and others i'm sure
Dims 28mm OD - Length - 35mm - Bolt 10mm.
see http://www.southwalesprops.co.uk/propsh ... n_visa.htm
April 27th, 2012, 8:50 am
Ah okay. I went with the biggest diameter I could find in the hope it would transmit the least vibration, I just wanted to check you hadn't found anything better.
April 27th, 2012, 10:45 pm
Nice little "how to" here about engine/gearbox mounts, although, like has been mentioned, they do look quite rigid.
http://www.how-to-build-hotrods.com/custom-motor-mounts.html
April 29th, 2012, 4:06 am
Rear Brakes.
Two lines the rear calipers. Can do fiddle brakes or (ambitious) traction control
Reassembled Transfer Box.
Oil Feed for top bearings
Oil supply
Solution for oil pump yet to found.
May 4th, 2012, 4:22 pm
This is a great thread. Can't wait to see the finished product. 8-)
May 4th, 2012, 4:24 pm
Eh pete i like the lateral thinking
how about making it from cnc ali block??
May 7th, 2012, 10:15 pm
@pony
Part that bolts to engine would be tidier but ££.
Now ....3 parts + 2 nuts + 2 bolts + bush
CNC ...1 part + 2 studs + 2 nuts + bush
Fitted the new mounts to the engine, MORE vibration and noise, not ideal for a road car.
May 12th, 2012, 4:53 pm
Re mounting and vibration
Are u sure no metal parts are touching
eg metal to metal as this would cause vibration
we have used these as engine restraints before with no agro
also no vibration on propshaft centre mount when i use them!!??
just got final drawing for me new chassis jig
so will be of to laser cutters on monday to get jig plate cut
Then Finally the New Chassis jig
only took 2 years to build
But it should be plus or minus 1 mm on 3800 mm long
I can live with that!!!!!!!!!!!!!!!
I will post pictures when its all Ready!
meanwhile Ant n me sand blasted a bodyshell in the yard
6 hours 100 KG fine sand and a 5 Quid blast gun !!!!!
i reckon good for us Bulkan boys!
May 12th, 2012, 9:33 pm
Mine is taking over 12 years now :lol: :lol: :lol:
May 12th, 2012, 10:03 pm
subarupete wrote:
@pony
Can it be that the mounts are oversized for a small 2cv engine and therefor not
flexible enough?????? (no deflection under the little weight and movement of a 2cv engine)
Try original mounts with nut and bolt....... as said before
May 12th, 2012, 10:07 pm
