View unanswered posts | View active topics It is currently August 18th, 2025, 1:34 am
Reply to topic  [ 10 posts ]
 Still rocking.
Post Still rocking.
Hallo all.
Any idea why my 2CV is still rocking back and forth after a complete stop from any speed?
:roll:
I've Been Wrong Before.
April 25th, 2012, 9:40 pm
Post Re: Still rocking.
Mine does it a tiny amount. But no idea I'm afraid
April 25th, 2012, 10:00 pm
When you pull up the car moves backwards and forwards slightly? The driveshaft sliding joints have a small amount of slop in them, as do, I guess, the 2cv joints. because the brakes are inboard I always assumed this was why any movement or play in any component between the wheel and the brake will allow the car to move slightly when the brakes are on.
April 25th, 2012, 10:10 pm
worn buffers on the floating suspension cans?
April 25th, 2012, 10:22 pm
It I am parked up I can rock my car slightly so mine is definatly not suspension buffers
I'm only curious it doesn't bother me
April 25th, 2012, 10:36 pm
'Rolling' or 'rocking'?
'They all do that', if it's the first one
Worn out dampers, if it's the second one.
Ken.
April 26th, 2012, 1:18 am
The shock absorbers are new ones Lipmesa correctly fitted.
No batteurs for me or friction dampers.
worn buffers on the floating suspension cans (What do you mean?)
Can it be the driveshafts? The rear brakes have no play afterall...
April 26th, 2012, 2:15 pm
the interlinked suspension that the 2cv is famous for? the fact that when the front wheels push up they pull the suspension forward and raise the rear so the whole car lifts and settles rather that pitching up at the front the dropping and pitching at the rear.
i set my car up with the maximum cleasrance of the buiffers on the suspension can and as you stop it feels like the chassis slides forward and back - thats not what actually happens it just what it feels like.
you have fittted your brand new shocks the right way round and the right way up?
April 26th, 2012, 8:45 pm
The shocks are fitted all right.
Is there so much compliance in the rubber canister rings?
I 'll check it with some chalk marks.
How much clearance do you mean?
Haynes dictates some 2mm only for the rear.
April 26th, 2012, 9:53 pm
Russel was right.
It was from the play in the driveshafts.
Sean what do you mean?
May 1st, 2012, 9:54 pm
