View unanswered posts | View active topics It is currently June 19th, 2026, 11:27 pm
 condensation/water in exhaust
Post condensation/water in exhaust
Hi,took my exhaust off today to reseal join,about an egg cup water came out exhaust,doesnt smoke much,just passed mot,emissions were low andengine seams to be running fine,is this normal for a 2cv or do i have problems ahead :o
April 22nd, 2012, 8:01 pm
Post Re: condensation/water in exhaust
I think it's fine however I may be wrong
Some of the original exhausts had a small hole in the torpedo silencer to
Let any water out (iirc)
April 22nd, 2012, 8:04 pm
Ok cheers James !
April 22nd, 2012, 8:07 pm
If I leave my 2CV ticking over on my drive it leaves a damp patch where water has literally blown outa the exhaust.
If it bothers you that much .....do as I do with my motorbikes,and squirt some WD40 [or preferably one of the cheaper alternatives] up the exhaust after a short run.
A long drive of course will heat the exhaust up so that most of the water evaporates anyway.
Edit .....and dont try this trick on a modern car,it'll prob'ly "fubar" the catalytic converter up.
hth
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
April 22nd, 2012, 8:30 pm
Water is a natural product of the combustion process and therefore nothing to worry about - just go for a long drive.
April 22nd, 2012, 9:04 pm
Thanks for all replies,will be able to sleep tonight now ! :mrgreen:
April 22nd, 2012, 10:15 pm
Have you checked the water level in the radiator and also for mayonaise in the rocker cover - could be a blown head gasket ;-) :o :lol:
April 23rd, 2012, 2:22 pm
Actually blackjack my Aircooled VW Bug used to suffer from Mayo in the oil filler and there was a special trap in the Air cleaner box to catch this.
Mayo in the oil can happen to aircooled cars as well as watercooled ones and can be due to moist air being sucked into engine (eg rain) , water ingress (through fording) and short runs where the oil has not got hot enough in damp environments (eg Great Britian).
1973 Ami 8 Club
April 24th, 2012, 2:23 pm
Quite right James. If you look at an original Citroen 2CV exhaust rather than a pattern one, you will see that the long tailpipe also has a 4mm hole at the bottom of the cranked section to allow water to escape. Some original swannecks also have a 4mm hole at the lowest point just prior to the torpedo. Water is usually more of a problem in the tailpipe as this is the last part of the exhaust to get hot and so evaporate the trapped water. This is also why the back box is almost always the first part of the exhaust you have to replace.
1973 Ami 8 Club
April 24th, 2012, 2:27 pm
and from condensate in the "blow by" to add to your excelent list of causes of mayo. :D
April 24th, 2012, 5:51 pm
Users browsing this forum: No registered users and 222 guests
