View unanswered posts | View active topics It is currently June 28th, 2025, 12:24 am
Reply to topic  [ 6 posts ]
 Cheap rev counter that works with 2cv with 123 ignition
Post Cheap rev counter that works with 2cv with 123 ignition
Found this on ebay and bought it on the understanding if it does not work could return it for refund. But hey presto works fine even with 123 evo ignition.
People very helpful.
http://www.ebay.co.uk/itm/370594104494? ... 1497.l2649
April 2nd, 2012, 5:56 pm
Post Re: Cheap rev counter that works with 2cv with 123 ignition
you did tell them it was a 2cv with a "lost spark" ignition - same as a HD
April 2nd, 2012, 6:01 pm
Yep - but they were not sure it would work but no problems. Running up without shakes etc and good finish on the thing
April 2nd, 2012, 6:13 pm
So this is a silly question
Will it work with standard set up
April 2nd, 2012, 6:50 pm
I bought a cheap tacho suitable for typical 4-cyl 4 stroke engine, 1 year ago and works since.
The signal connection is on the coil.
:idea: The lost spark is not a problem as is the same sparks/revolutions rate as a 4-cyl.
I've Been Wrong Before.
April 2nd, 2012, 7:16 pm
Hi Jameswallace,
I should it would be fine. 123 only gives a signal as per the points
April 2nd, 2012, 7:31 pm
