Author |
J-dub
 Re: Dave 411's 1967 AK350.
Sam, Did you test your manonomonomonometer on something you knew work?
March 17th, 2012, 9:16 am |
Jameswallace wrote: Sam, Did you test your manonomonomonometer on something you knew work? what like atmospheric pressure? a u shaped tube open at both ends& filled with lhm - cant not work all you are doing is measuring the small differance in pressure between either end - plug one end in the dipstick tube. DSC00079 by Sean602, on Flickr
March 17th, 2012, 10:20 am |
J-dub
Sean, yes I use those at work But as I understand it of there isn't a good connection to what your testing the results could be inaccurate? Not saying you've got it wrong just curious, Sam
March 17th, 2012, 11:22 am |
James, if it was possible to create a perfect vacuum inside the crankcase, a water manometer would need to be 34 feet (408 inches) high in order to measure it. Considering that an acceptable difference in level of the liquid in the manometer legs is only 2.5 inches, that should give you some idea of just how feeble the crankcase 'vacuum' is in real terms. Any instrument will give an inaccurate reading if it's not properly connected, with an engine manometer all that's needed is a good seal between the plastic pipe and the dipstick tube. ken Jameswallace wrote: Sean, yes I use those at work But as I understand it of there isn't a good connection to what your testing the results could be inaccurate? Not saying you've got it wrong just curious, Sam
March 17th, 2012, 1:29 pm |
Neil
y0! Any updates on this Dave401892876390? Nearly two months have passed & I'm getting impatient.
May 12th, 2012, 10:55 pm |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
Well,funny you should ask.I have had the gear box back from Rick and am in the middle of assembling the brakes,pics to follow later today. The chassis has gone off to be powder coated,should have it back next friday.Then I can assemble it,re fit the body and take it to Graham in Cornwall to have the floors and kick panel done. Then is just a case of putting it all back together.Almost everthing else is done,just a few things to sort out,black box etc. I will post pics as I go along.I must admit,I am getting slightly frustrated as it has slowed down considerably lately,but once the chassis is done,it should be full steam ahead  .
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
May 13th, 2012, 10:15 am |
J-dub
 More to follow
May 13th, 2012, 6:41 pm |
Russell
Either Daves fucked his van right up or you've posted in the wrong thread. But good work James.
May 13th, 2012, 7:16 pm |
J-dub
My appologise dave. Thought I was in my thread
May 13th, 2012, 7:59 pm |
dave 411
May 14th, 2012, 9:24 am |
Users browsing this forum: No registered users and 23 guests |
