View unanswered posts | View active topics It is currently April 27th, 2026, 12:56 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 105  Next
 Make Your Own ....2CV.... 4x4
I had a feeling that would happen :lol:
March 12th, 2012, 10:46 pm
Well thanks for the heads up :D
March 12th, 2012, 10:58 pm
its cause you built that 2cv back to front
like a Terminator the 2cv is rising from the carnage and trying to re assemble its self, you cant kill them you know!
:lol:
March 13th, 2012, 9:09 am
Like the idea :)
March 13th, 2012, 10:00 am
Put everything upside down then your heading in the right direction
(I guess) :idea:
March 13th, 2012, 9:19 pm
Need to swap the diffs, the other way (inside the housing).....
Not such a task as the have been taked apart and assembled a number of times and they are also nice and clean.
Note to self.
“Never assume, you’ll make an ass out of you and me”
March 14th, 2012, 10:51 am
Having waited 3 months for a local macine shop to make some drive shaft adapters for the rear gear box , I embarked on making my own, using the front ones for dimensions.
Used QCAD to make a drawing.
Laser Cut or Water Jet ?
Laser cheaper whereas Water Jet is more accurate and can do small holes but expensive.
Opted for Laser with the hole positions marked up.
Use a sharp centre-punch and an eye glass for accuracy, to mark out the centre-points for drilling.
Hours with the drill press/9mm and 10mm taps....
Blank Laser Cut
Used 10mm Hex nut onto Gearbox flange.
Fitted 2CV Inner flange.
It all fits together :o
March 16th, 2012, 5:52 pm
That's absolutely flipping excellent.
I love to see things like this.
March 16th, 2012, 8:45 pm
Nice one Pete!
March 17th, 2012, 10:59 am
TOPIC - Propeller Shafts
Fitted the centre prop shaft bearing (One of Louis B excellent products)
First attempt at prop-shafts number 1 of 3...
The Before..... far too long...
Correct length, but will require my best welding efforts...
Also need to find the correct flange
March 18th, 2012, 5:00 pm
