View unanswered posts | View active topics It is currently June 26th, 2025, 8:19 am
Reply to topic  [ 10 posts ]
 Chassis Change Paperwork
Post Chassis Change Paperwork
Hi guys,
The chassis in the Charleston needs replacing, and I have no idea what sort of paperwork this is gonna need. Will the car need an SVA afterwards or anything? I don't want to end up with some crappy Q-Plate on it, and seeing other chassis swaps that still keep the original, I assume there's a proper way of doing it.
Is it anything to do with using new/used chassis? Or does it have to conform to some original specs or something? We have been looking at a couple of used galvanised chassis, one of which is pretty much a 2cv with the body off, comes with the v5 and everything else. Is this a bad idea?
And er, I realise I might be opening a can of worms but, what do people recommend for a new chassis, if that's the route we need to take? I think I know one to avoid.
Cheers
1985 Black 2CV Spécial.
February 16th, 2012, 10:49 pm
Post Re: Chassis Change Paperwork
Get an SLC chassis, it'll be the best. Don't worry about a chassis change, most people won't know or care.
February 16th, 2012, 10:56 pm
You won't need to to anything. Just change the chassis, fit the old vin plate to the new chassis and that's it. It's not a job that requires any paperwork doing and you don't need to notify anybody.
Best chassis is either original Citroen or SLC. PM Ken on here, he makes the SLC chassis.
February 16th, 2012, 10:58 pm
Ah right, good stuff, cheers guys.
February 16th, 2012, 11:26 pm
On anything younger than the 70s the VIN plate won't even be on the chassis, it's on the bulkhead under the bonnet. I've seen a 2CV body in a scrap yard minus the chassis and the scrap yard refused to sell the body because the VIN plate was on it, even though they had happily sold the chassis on (galv. job apparently). The shell was almost perfect, so God knows why it was there for. :(
February 17th, 2012, 12:02 am
and in balance ,
other, crappy chassis, are available.
February 17th, 2012, 12:04 am
Should of prized the vin plate of the shell
My replacement chassis has it etched in
Yep, it is, I thought there was gonna be another on the chassis. That's good.
Sean wrote:
and in balance ,
Yeah, from searching about I think I got a good idea which to avoid. ;)
February 17th, 2012, 12:20 am
Sean wrote:
and in balance ,
But don't buy one.
February 17th, 2012, 12:39 am
February 17th, 2012, 8:54 am
