My new 2CV, running restoration. In theory..
Author |
J-dub
 Re: My new 2CV, running restoration. In theory..
Wow amazing stuff!!! I do hope this gets serious rust proofing
December 25th, 2011, 11:02 am |
48pop
Joined: May 23rd, 2011, 7:14 pm Posts: 309 Location: ecosse
Really, really nice work !!
December 25th, 2011, 12:43 pm |
panelbeaterpeter
Joined: April 24th, 2011, 6:05 pm Posts: 226 Location: Everywhere
Thanks guys, yes it will be getting pumped full of waxoyl, and thoroughly painted everywhere.
_________________ (°\=/°)
December 29th, 2011, 6:54 pm |
January 9th, 2012, 8:56 pm |
panelbeaterpeter
Been a while.. spent this weekend messing about in the garage. Got a wing sorted, genuine new ones are too expensive and non gen ones don't fit, so decided to fix the old ones, starting with the better of the two. This area was a bit crusty  Cut out  Made new one  And welded in   This bit was also a bit rough  Cut out and welded   Due to most 2CV wings seemingly doing this at the top of the arch;  ...and generally being quite weak, I got some 4mm steel bar  And welded it round the inside lip  The difference in strength is amazing, so much more solid, feel like I could almost sit on it. Repaired creased area   Blanked the side indicators, will relocate these somewhere else later.  A 5p did the job nicely   Thought I'd have a play with the front indicators, and get rid of the horrible big plastic ones.  Hole filled in    Cut out again..  Bent a bit..  More metal added..  And add some old Lucas 488 sidelights, fitted with amber bulbs.. Looks a bit more retro..  I also fitted new A panels, but lost the pics. Will post if I find them Can't wait to do the next wing.. ¬_¬
February 6th, 2012, 2:36 am |
as always a shonky series of bodges - poor car you sholld be giving it a name, having some sort of post 70s acid come down charleston colour way and some stick on trinkets
>sigh<
seriously, the wire edge wing is something my mate Norry used to do on the racer makes the wings soooo much stronger and certainly stood up to jostling. whats the indicator looks good
February 6th, 2012, 9:20 am |
panelbeaterpeter
You've hit the nail on the head there, just the look I'm after!!
The lights are sidelights or reversing lights, 50's and 60's Lucas L488. Like early mini indicators but with a flat lens and inset bulb. I might fit amber lenses, not sure yet.
February 6th, 2012, 2:59 pm |
Looking grand, as expected. Have you put drain hole in the recessed parts? The characters I once worked with built a 2CV-based buggy with frenched rear lights and no drain holes, which made some very successful rust traps...
February 6th, 2012, 3:57 pm |
panelbeaterpeter
Good point Ken, I hadn't thought of that.
February 6th, 2012, 5:01 pm |
Jonathan
Any updates with this?
May 12th, 2012, 10:58 pm |
Users browsing this forum: No registered users and 34 guests |
