View unanswered posts | View active topics It is currently June 19th, 2026, 9:21 am
Reply to topic  [ 36 posts ]  Go to page 1, 2, 3, 4  Next
 New member,Kingpins for the first time!
Post New member,Kingpins for the first time!
Hi everyone,although i have had many classic cars this is my first 2cv!
I`ve tackled a few jobs but tonight i`ve stripped one side to replace the king pins,everything has gone to plan and i was at the stage of putting the dummy kingpin (ecas set) in to adjust the vertical play.......
The question is, with all of the spacers dust cap etc in place i can`t get it all to go together as there is is no clearance at all, i only had time for a few gentle! taps with a mallet before i came in! So can you get different thicknesses of washers to the ones supplied from ecas? Bearing in mind i need thinner not thicker.
Also i feel the "eye" on the suspension arm is a bit worn but obviously you can`t really tell until you have it all back together properly shimmed up and greased can you!! After i`ve done a few I`ll probally get a feel for it,but for now any comments or advice will be gratefully received.
Thanks Andy
June 2nd, 2009, 12:37 am
Post Re: New member,Kingpins for the first time!
Help here
http://www.aussiefrogs.com/forum/showthread.php?t=60146
Happy working
Viking
June 2nd, 2009, 9:33 am
Old Bloke
2CViking wrote:
Thats as good an explanation of fitting that I have seen. Don't be hittings things Andy, if you have cleaned everything and got the shims and slip washers in the right place it will go back in place by hand.
P
Now known as 602
http://www.2CVTech.co.uk
June 2nd, 2009, 9:46 am
mowcopds do you live in mow cop
June 2nd, 2009, 6:31 pm
Thanks for the replies everyone!
I just love forums! its great to talk to people with similar interests but more knowledge!! it would take ages to get this info otherwise.
I think i can make it work but fear that the suspension arm holes are on their last legs,i just hope it will pass the mot one more time.
To 2cv4x. yes i do live in Mowcop well spotted!
June 2nd, 2009, 8:11 pm
Do you have access to a welder? you can close the holes in the arm quite easily by grinding two slots around the outside and filling it with a hot bead of weld. The weld metal shrinks as it cools and that tightens up the hole.
June 2nd, 2009, 8:39 pm
Old Bloke
Hmmm :!:
Now known as 602
June 2nd, 2009, 8:53 pm
Sorry but no. I have very strong views on doing the job properly.
If you can wait 2-3 weeks, I have oversize king pins in stock. Standard pins are 17 mm in diameter. The oversize pins are 17,1 and 17,2 mm, specially designed for swing arms with ''worn out'' holes. Any other ''repair'' is a compromise
June 2nd, 2009, 9:10 pm
Hmmm :!:
I've done this successfully, it works!
June 2nd, 2009, 9:11 pm
Old Bloke
I shall bow your excellence in weldingness
P
Now known as 602
June 2nd, 2009, 9:20 pm
Users browsing this forum: No registered users and 203 guests
