View unanswered posts | View active topics It is currently November 20th, 2025, 11:39 pm
Reply to topic  [ 7 posts ]
 Speedometer cable routing through bulkhead
Post Speedometer cable routing through bulkhead
My last speedo cable lasted about twenty miles, throughout that time the needle wavered a lot. I guess I got the routing wrong, the cable sheared at the speedo head. Should it route through a separate hole in the bullhead, or just with the rest of the wires?
Thanks , Ben
January 14th, 2012, 6:20 pm
Post Re: Speedometer cable routing through bulkhead
Looking half way down here http://www.keiths-classic-cars.org.uk/c ... -dolly.htm, i can see that there are two cables to the left of the master cylinder. One I guess is choke, and the other is speedo?
January 14th, 2012, 7:38 pm
Ben,
aren't those are the choke and throttle cables?
On that site you've mentioned, find the picture with the heading 'the wax fest continues', just in front of the battery is the (grey) speedo cable, which goes through the bulkhead near to the n/s heater stub.
edit: also visible in the photograph titled 'and continues'
Once inside the car, it goes along underneath the parcel shelf, then passes through a hole in the underside of the instrument binnacle to arrive at the speedo.
Btw, I think I recall hearing that there were some dodgy speedo cables on offer, on which the 'squared' end of the inner cable was undersized, so that it would spin in the socket on the speedometer head.
Didn't Old-Nail find that the one he'd bought (at best priiice) and which failed in short order had a 'Peugeot' label on the wrapping? :roll:
January 14th, 2012, 9:34 pm
Out the side of the binnacle along the top of the shelf(under the felt and vynil "trim" - no photos im afraid
down through the parcel shelf
DSC00224 by Sean602, on Flickr
out the bulkhead above the handbrake linkage
DSC00223 by Sean602, on Flickr
to come out by the heater stub
DSC00220 by Sean602, on Flickr
and down to the 'Box
January 14th, 2012, 10:32 pm
Thanks gents.
Worryingly , the replacement speedo cable I have (best price, natch) does have Peugeot on it. I think the first one failed because I spectacularly failed to route it correctly. Hopefully correctly routed it will work better, thanks sean for the pics they will be very useful.
What I incorrectly noted as the cable, is certainly the throttle, which is why i only have one hole in the bulkhead in that area on my car.
January 14th, 2012, 11:02 pm
The route citroen chose for the cable does seem unnecessarily complex to me. I drilled a new hole in the bulkhead directly behind the speedo.
January 14th, 2012, 11:40 pm
Crikey only been here 5 minutes and my D*lly pics are being used for "reference" purposes.
I am humbled :shock: :mrgreen:
January 15th, 2012, 1:36 am
Users browsing this forum: Google [Bot] and 14 guests
