View unanswered posts | View active topics It is currently November 21st, 2025, 4:26 am
 rear bump stops.
Post rear bump stops.
Happy new year all,
2cv rear bump stops,my passenger side rear rubber is missing and bracket corroided,can you buy complete thing to weld onto body or just rubber,cheers :)
January 1st, 2012, 5:10 pm
Post Re: rear bump stops.
You can buy all parts from ecas.
January 1st, 2012, 5:12 pm
Great.thanks Russel.
January 1st, 2012, 5:41 pm
If you search their website for bump stops or similar you'll find it.
January 1st, 2012, 5:45 pm
http://www.ecas2cvparts.co.uk/advanced_ ... op&x=0&y=0
That should do it...
January 1st, 2012, 5:47 pm
Problem is if you've lost just the rubber, you can't buy a rubber to fit the original mount with the metal retainer bit.
If you need to weld in a complete mounting then it's a different design and a different rubber comes with that.
I got round not having the metal retainer for the original type using a coach screw, large washer and a lot of swearing and fiddling it into position.
Dyane 6 1981
LN 602 1977
2cv Bamboo - Green Bean 2 (Raid Imber Car)
January 1st, 2012, 10:00 pm
:? After some MOT welding on my 2CV I noticed that my [rear] bumpstops were missing from the new inner wings I had fitted.....[FWIW...... they were both missing from what was left of the inner wings anyway] :oops:
Anyhows ;) .....can anyone explain just what useful purpose they serve .....and are they actually MOT'able.
btw .....my 2CV passed the MOT without 'em.
T.
2CV6 Special [Red]
C4 VTR+ Coupe [Black]
January 3rd, 2012, 1:09 am
Obviously my cars are always run low so they use the bumpstops all the time, but I reckon if you loaded a normal 2cv up with a lot of weight, two rear passengers and a boot full of shopping, a boot box, a cycle rack, a boot rack and a picnic basket hung from it (you get the idea) then you'd want the bumpstops to stop the fuel tank rubbing the floor.
January 3rd, 2012, 1:13 am
I am so bad at anything technical, so take this with a pinch of Lard....
....however...I chopped them off ......simple....didnt see the point.
A bit like wisdom teeth !!
I admit to driving the car on my own or just with one passenger...so the weight bit dont matter....they just seem an area for extra rust and water to collect .....and so grounded off !
I would rather spend my money on other stuff than "bump stops".....
January 3rd, 2012, 1:23 pm
Thanks for all replies,after a bit head scratching i made my own today,adapted
a volvo lorry cab mounting rubber i found at work today :D
January 3rd, 2012, 5:40 pm
