View unanswered posts | View active topics It is currently November 21st, 2025, 2:09 am
 Special Tools
Post Special Tools
Hi folks,not something I would normally ask,but I need to hire/rent/borrow some special tools.I need the tool for removing the pinion gear from the steering rack and either one or two 50mm open ended spanners to remove the suspension cans on my van.Will need them fo a couple of weeks and will arrange collection etc. I will pay for the use of them,thats not a problem.I would normally buy special tools,but I cant see me ever using these again.
If you can help,PM me.
Many thanks,Dave.
December 29th, 2011, 1:17 pm
Post Re: Special Tools
Dave
Are the suspension nuts not 46mm?
If so,
I used a set of teng tool mole grips to do it. Not 'proper' but worked fine
December 29th, 2011, 2:31 pm
Van.
waterpump pliers.
December 29th, 2011, 2:33 pm
No,they are a whopping 50mm.
Sean wrote:
Van.
waterpump pliers.
I was thinking of them.My pliers are not big enough.Tried a pair of Vice Grips,wouldnt touch them.Stuck fast :(
December 29th, 2011, 2:36 pm
ahh fair enough
look on ebay dave
December 29th, 2011, 2:47 pm
large stilsons :?:
December 29th, 2011, 5:30 pm
Dave,
don't think you'd go too far wrong purchasing one of these, by the time you've taken into account the cost of posting a similar spanner out and back.
http://www.ebay.co.uk/itm/Gedore-50mm-S ... _500wt_949
The other advantage with this one is that it's a proper piece of kit, not something laser cut out of mild steel plate, which may look like a spanner, but that's as far as it goes. :roll:
Half the battle in undoing those end fitting nuts is parking the spanner on a nut and giving it a few thumps with a 4 lb lump hammer.
Rotate the whole fitting to the next flat and repeat until the nut is free.
Don't forget to loosen the inner nuts (closest to the suspension canister) first, as you can deal with the outers once the suspension is removed from the chassis.
( p.s. I've got an OE tool for removing a steering pinion which you could borrow, but it would have to be on a 'break it or lose it, you replace it' basis, as it's something which I use regularly when rebuilding racks. Even that small lump of steel weighs 0.5kg, btw )
December 29th, 2011, 7:27 pm
Hi Ken,It really is a small world.JW suggested to look on e bay and I found the same Ad.
I have made an offer,but if they dont accept,I really dont mind paying the asking price.Maybe I am just being silly,16.00 is cheap for a spanner that size.The 46mm ones I bought cost me over 30.00each.
Ken,if you are willing to let me use your tool :lol: :lol: :lol: ,I would of course replace it if it got lost or damaged.I can arrange collection,and as I said,will gladly pay a fee for using it,thats not a problem.
If you are willing to do that pm me your address and I will arange collection.
December 29th, 2011, 7:37 pm
If your doing the Steering Pinion, use this as a replacement part
http://www.ecas2cvparts.co.uk/steering- ... -1219.html
Dave
I could drill/tap for a grease nipple if you like.
Peter
December 30th, 2011, 2:12 pm
Users browsing this forum: Google [Bot] and 4 guests
