View unanswered posts | View active topics It is currently November 20th, 2025, 11:55 pm
Reply to topic  [ 72 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
 2cv Mods and Improvements (totally subjective) ( . ) ( .)
Post 2cv Mods and Improvements (totally subjective) ( . ) ( .)
Hi legends,
I've started this thread as i am half way through rebuilding my 2cv and would like to hear other peoples recommendations for any type of mod that they have done to improve there 2cv... Be it for raiding, racing or rooting, whatever... Any ideas above and beyond general maintenance... big or small, practical or ridiculous...
What I have done so far to make it more practical/modern...
Megasquirt efi
Twin spark 652cc
123 ignition
LNA Gearbox
Yellow Coil
Reed valve engine breather
Captured fan housing bolt (allen key bolt that pulls the fan off as it is undone)
Larger oil filter with Temp and pressure gauges
Cylinder head temp gauge
Uprated Springs 20%
Roof Entendach Superior
Reinforced chassis, PO spec.
Twin spark 652cc
What I am about to do:
Replace the steering track ends with rose joints, Joolz inspired.
Oil Accumulator and Oil Sandwich Plate thermostat
Modified oil circuit
What I think would be worth looking at:
Grease nipples! where to retro fit them for easy serviceability and long life!
Steering rack guide ring, replace with a nylon bush?
So if there is anything you have thought is worth an improvement, lets hear it!
Cheers,
December 29th, 2011, 10:44 am
Post Re: 2cv Mods and Improvements (totally subjective) ( . ) ( .
Braided oil feed pipes to the head, I assume visa engines also have these, but if not they seem to be a better idea than the rusty fatigued Citroen versions.
December 29th, 2011, 10:59 am
( .Y. ) natural not silicon!
absolutley nothing apart from a method of removing the condensor from the points set up
"improvements" often come with added complexity and thats not what the car is about in my view.
Some little bits to make maintenance easier grease points on the rack: some stuff to repair the original bits that broke/wear out when the replacements are sub standard - copper oil lines to heads, silicone valve in the breather.
December 29th, 2011, 12:28 pm
My 2 cents.
1 - Grease nipples on any bearings. Cost effective - (Grease Nipple + labour) vs cost of bearings.
2 - Wiring Loom - Use thinwall cable, pre-insulated terminals and a few relays.
December 30th, 2011, 1:30 pm
Some more thoughts...
1. Take circuit board off 123 and seal with mastic to waterproof it. Likewise for where cables come out.
2. Put relays & fuses in plasticclip lid lunchbox on bulkhead. (Fix lid to bulkhead). This keeps them waterproof.
3. Make quick release lighting bar by using caravan to bar electrics
4. Fit 12v small computer fans above rear window to demist when damp and blow air round car when warm.
I can probably sort some photos of these if required...let me know...
December 30th, 2011, 10:40 pm
Buy a new car??? Surely your losing all the fun of 2cv motoring?
December 31st, 2011, 12:26 am
I doubt a new car could put up with the conditions my 2CV has been thru!
And if I did but a new car and tried to modify it to keep the water out, stickyback plastic and a tupperware box would not really do the trick :lol:
December 31st, 2011, 12:35 am
Demist the rear window using just the PC fans - is that really efficient?!
I usually use a closed umbrella with a cloth on top of it. It works but it isn't comfortable... :roll:
December 31st, 2011, 1:52 am
Well I've had them in the 4x4 sine 2004. Worked fine in raid Laponie -28c and Raid Poronkusema 2009.
Been thru deep water at Langdale quest and the whole car steams up and the back screen always demists.
You can see them in the rear window here, I have 5 ripped out of old computers. 60mm draw less than 0.2 amps each!
I'll try todig out a better photo later.
December 31st, 2011, 2:06 am
Nice ideas guys,
I pulled apart my rack yesterday and was pleasantly surprised at how little wear & tear there was, although the pinion bearing feels a bit lumpy there is no play in it at all, so i think it will last another decade no problems.
The grease nipples seem the smart way to go, I can see the practicality of having them on the suspension arm bearings but where to put one on the steering rack?
Having had the rack apart I can see that a lot of the original grease has sat there untouched for many years... This looks like a good solution but I guess it will only grease the pinion bearing:
Relays and waterproof fuse box is a win as is improved oil feed lines.
CHeers,
December 31st, 2011, 4:02 am
Users browsing this forum: Google [Bot] and 15 guests
