View unanswered posts | View active topics It is currently August 15th, 2025, 1:38 am
Reply to topic  [ 5655 posts ]  Go to page Previous  1 ... 300, 301, 302, 303, 304, 305, 306 ... 566  Next
 The O/T thread!
Post Re: The O/T thread!
Scalextric + 2cv = Image...enormously expensive BMW concept!
December 13th, 2011, 1:56 pm
Jameswallace wrote:
Russ do you want a carb to borrow to
Get it throUgh?
I recon like I said the other day whichever you're you'll regret it,
Thanks cupcake, I might take you up on that come the spring if. Don't sack the old crate off. Much love.
December 13th, 2011, 9:55 pm
Get it throUgh?
No Problem,
Its a dyane carb, but failing that working feel free to pinch the known working one of for mot purposes ;)
December 13th, 2011, 11:23 pm
James,
no such thing as a Dyane carb, exactly the same item was fitted by Citroen to 2CVs, Dyanes, Amis, etc. at various times...
Jameswallace wrote:
No Problem,
December 14th, 2011, 12:12 am
Thought the jetting was different?
December 14th, 2011, 1:23 am
Nope,
should have been, to compensate for that 'forced induction' on Dyanes and Amis, but it wasn't... :lol:
December 14th, 2011, 1:38 am
Really, please explain 21-24 vs 18-26?
December 14th, 2011, 10:21 am
IIRC
Some Dyanes had 18/26 the later ones.
There are lists of applications with differing engine types AM2-M28, AK2 M28/1 for Dyanes and AK2-M28/1, A06/635 - M28/1 for 2cv6. Carbs are listed with myriad applications and serial numbers (presumably for the miniscule jet changes and location of various adjustment screws and linkage types) and we will not even get into the various permutations of van engines with and without 9:1 pistons
"18/26" and "21/23" refer to the veturi bore in the two types of carb its easier than the "34 pics/pcis-123/ 124" that Solex gave to them. Its also cast into the side of the body and so is permanent, unlike the tin tag with the solex details on it that eventually falls off. Think its a UK racing thing where both carbs were permitted and so it was easier to say 'yeh, we're running a 21/23' or were running a "Dyane" carb
Its common to say that the 21/23 is a "Dyane" or "Ami "carb because thats where you are likley to find them and where most of them went, but the Dyane also came with the 18/26 towards the end.
The 18/26 is commonly referred to 2cv (D*lly) carb because it has them untill the end
I also think that some of the middle 2cvs came with the 21/23 around the disk brake and flywheel changes time.UK market was odd as some cars were built and stuck in storage for a while and so the year of registration and the build year were different.
Im pretty sure the jets remained the same if the 18/26 carb was in a Dyane or a 2cv, jet sizes are determined by the venturi of the carb but im not going through pages of carb spec and jet sizes just for an "angels dancing on the head of a pin" type discussion
Enjoying the heat in Aus?
December 14th, 2011, 11:02 am
Post for sale /wanted
Do you get the feeling some folk are not speaking to each other?
:lol:
Screenshot.pdf [178.65 KiB]
Downloaded 198 times
December 14th, 2011, 11:38 am
Hi Sean,
to fill in a few dates, twin choke carburettors were fitted to 2CVs from 1978.
(Wonder if Citroen had crates of them lying around with the demise of the Ami?) ;)
From 1980 onwards, the 21-24 type carburettor was replaced with the 18-26 type on both 2CVs and Dyanes.
Jetting on the 21-24 type was 120 (or occasionally 125) primary and 70 secondary, whereas the 18-26 type had 102.5 primary and 87.5 (or 90) secondary.
The Dyane which I bought new in 1980 would not run properly on a light throttle with the original jetting and after Citroen had tried 2 replacement carburettors under warranty, I ended up rejetting it myself.
That's some answers so here's a question to keep things going...
Why do you think Citroen 'detuned' the Dyane engine from 9.0:1 to 8.5:1 when is was fitted in Acadianes, identifiable by its purple/lilac engine number plate?
Sean wrote:
IIRC
December 14th, 2011, 1:11 pm
