View unanswered posts | View active topics It is currently November 21st, 2025, 8:56 am
Reply to topic  [ 6 posts ]
 headlight adjustement bar
Post headlight adjustement bar
Guys good morning .
i am trying to adust the headlights. I was thinking that if i put the wings then all will be set in position looking straight ahead.
So yesyerday i installed the wings but nothing got straight.
So is there a tip.? I am thinking that the bar through the years and crashes got bend.
Any tip on how to make headlights looking forward ?
November 26th, 2011, 8:33 am
Post Re: headlight adjustement bar
Are yours looking backwards?
November 26th, 2011, 9:58 am
No but they dont look at the centre of the car . the Bar is closer to the left cylinder than the right one.
November 26th, 2011, 10:09 am
Hmm, without looking at my car I can't give you a answer which is wrong and soon to be corrected by someone ;)
Ken or Sean will be along soon ;)
November 26th, 2011, 10:14 am
maybe not!
Pavlos unless there has been bits cut out from it then fail to see how it is off.
you may have to be carefull how you attach the wings /fenders as the whole thing is unstable and wobbly untill is all tightened up.
Could just be that the actual light is not central on its ball mount on the end of the bar, loosen the 19mm bolt and swivel it about till you have it how you want it.
November 26th, 2011, 10:26 am
Guys i ve found it . the horizontal bar was not straight . i took a piece of metal and a pipe wrench and flame heat it , and bend it back.
thanks again guys.
December 2nd, 2011, 9:20 am
