View unanswered posts | View active topics It is currently February 3rd, 2026, 7:55 pm
Reply to topic  [ 290 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 29  Next
 The Dirty 'D'
Post Re: The Dirty 'D'
The wheels are stock as a rock!!!
At the moment i have only one spare Ken, a bigger one, the plan is to have a smaller second spare under the bonnet ;)
Just removed the stop rubbers... for my sin's.
www.evilbens.blogspot.com
November 2nd, 2011, 10:07 pm
awesome, sent you a pm btw
November 2nd, 2011, 10:13 pm
After driving the Dyane for two weeks now my confidence is growing by the day, going round corners a bit faster giving it a bit more in each gear!!
I would happily get in it and drive to anywhere in the country, it really is smiles per miles.... it handles so well..
unlike a swing axle beetle, unsafe at any speed....
November 8th, 2011, 8:54 am
ha ha ha just wait till the summer when you start seeing VW in the distance then think "Ill 'ave him" then crusing by nonchalantly not making eyecontact - but still having a wee peak to see if there is any reaction :lol:
Dyane should cruse across continents at 70mph+AND go round corners- up rated springs, gear oil in the shocks next
hope this isnt the VW scene discovering the joys of Citroen....Panelbeaterpeter, Evil Ben, and a few otherer in the last couple of years ;)
November 8th, 2011, 9:14 am
Well it is!!!
November 8th, 2011, 9:36 am
Got the check strap's many thanks Jack!!! not got them fitted yet, it was one of those days.
Hopefully after work tomorrow.
November 14th, 2011, 11:52 pm
no worries ;)
November 15th, 2011, 7:18 pm
I had noticed a very slight pink when going up steep hills ( this is Cornwall) in fourth gear with my foot pushed hard into the floor, so a guess the timing is a tad out. Having not been able to spend time on the ' D ' with work being crazy at the moment i decided to put super unleaded in, 97 Octane until i get it sorted....
No more pink!!! so should i run 97 Octane all the time? I guess thats what its designed to have.......
Or glue a small bit of four by two under the pedal and save even more on fuel.
November 22nd, 2011, 12:52 am
Retard it a bit, it shouldn't pink even with 95 jungle in it.
November 22nd, 2011, 12:54 am
Or, [edit; as Russell's already advised]
since you're so close to having optimised the ignition timing, retard it by a small amount, perhaps half a tooth?
I'll leave you to do the maths as to whether the slight reduction in mpg with less advance is offset by the greater cost per litre of higher octane fuel...
p.s. A standard 2CV engine, with 8.5:1 pistons should be fine on 95 octane @ 33* max advance, 9.0:1 or higher will need less advance for the same octane.
November 22nd, 2011, 1:50 am
Users browsing this forum: No registered users and 748 guests
