View unanswered posts | View active topics It is currently February 4th, 2026, 1:08 am
This topic is locked, you cannot edit posts or make further replies.  [ 183 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
 1968 Ami Club Break
Post Re: 1968 Ami Club Break
Paint
Citroen assistance on the roof too!
Are you brush painting it?
September 6th, 2011, 8:56 am
Mwah, just a logo. Will be quite a big one.. maybe Citroen beneath it.
Painting it with a roller. Some photo from the already painted panels can be found here:
viewtopic.php?f=5&t=1850&start=50
the roller and paint I use are on the next page ;)
September 6th, 2011, 9:02 am
started today, so the ami wont be on the road for a few days/weeks..
First job is the roof, the biggest part that needs painting ;)
Start sanding at the front and worken to the back of the car.
Once at the back, I discoverd some corrosion at the point where the roof and the metal strip that lays over the roof/body seam.
Took the metal strip away and discovered that the roof was only held on the body with 2 of the 6 pop rivets that need to be there.
This is how it looked when I removed the strip.
This is how it needs to be
Old glue, which just was loose between the body and roof.
Sanded body and roof seam with some scoth brite, to make sure the new glue would attach good to the roof.
Filed the holes for the rivets a little bigger, so the new rivets fit. after that I sprayed some tectyl on the two parts.
Glued and riveted the roof back in place. To prevent water getting between the two parts, I put some outdoor sealant on the seam.
Then started painting:
This part will get coverd with the metal strip. Strip is painted black on the inside, and blue on the outside.
From the front
September 10th, 2011, 3:56 pm
Put some yellow paint on the car yesterday, after some sanding (passengerside rear door needed some bondo) and after closing some holes at the bottom of the windscreen surround with sealant :oops: :lol:
Took the front fenders and hood off the car, since I already got some painted panels in the garage (for over a year now)..
Inner rear fender on the left side, was just as the one on the right in a good condition. Cleaned it, and put some tectyl 190 base coat.. it will get some underseal when the fenders get back on the car.
Drivers door upper hinge will need some welding in the near future. I spotted a small crack on the hinge.. :(
And some pics:
windowframe will look better, eventually ;)
September 25th, 2011, 8:43 am
all the panels now have 3 coats of yellow, should be good now.
today painted some blue on the car:
Hope I can have it ready by next week, so i can bring it to spa..
Depens on how much light there is in the evenings, since the garage has no electricity
October 9th, 2011, 12:56 pm
I like it! Certainly brightens it up. Hopefully it will stop people driving into it now. Looking forward to seeing it at spa.
October 9th, 2011, 3:53 pm
getting there, slowly..
Mounted fenders and bootlid today:
October 12th, 2011, 8:22 pm
Front is back together, and de rear passenger door on the left has been changed.
Not mucht left to do now:
electrics on the back, doortrim on the right side, and some small bits.
only the front needs some paint, but that will be done next spring
October 13th, 2011, 8:08 pm
looks petty narly! 8-)
October 13th, 2011, 9:36 pm
Some small work from yesterday: logo and moulding on the bootlid
Today the rest of the moulding, some small other things and started the car for the first time since I started painting..
Only the front needs to be done, only in which colour..
Yellow would be the best option, but need to put 3 layers on it before it looks good.. blue will be done with two layers.
October 22nd, 2011, 8:01 pm
Users browsing this forum: No registered users and 818 guests
