View unanswered posts | View active topics It is currently November 21st, 2025, 4:29 am
Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 652's??
Post Re: 652's??
Two-pot Wheezer on fleaBay for parts...
http://cgi.ebay.co.uk/250618173294
(Usual "Auction for a wheelnut" - call Kevin on 07847 214722 for anything else)
April 19th, 2010, 6:56 pm
Post Re: 652's??
Harry! You need this!
April 19th, 2010, 7:22 pm
Post Re: 652's??
Shorly do! Bit far tho :(
Low and Loud!
April 20th, 2010, 12:02 am
Post Re: 652's??
Right I've found someone to bore out my barrels so if I just get some visa pistons can i just whack them in or do i need visa heads and/ or all sorts of other stuff? And will it give me what I want?
Low and Loud!
September 28th, 2011, 4:27 pm
Post Re: 652's??
Don't bore your barrels out, the 602 suffers with seizing/partial seizing as is, it'll be much more prone as a 652. (Apparently, the 435 never suffers with seizures, as there is much more metal round the bores).
September 28th, 2011, 5:10 pm
Post Re: 652's??
The Visa uses nicosil plated alloy barrels which need something different about the piston rings, I can't remember what it is though and may even have imagined it. Have you trawled cats, there's lot of info on this sort of stuff there.
September 28th, 2011, 10:51 pm
Post Re: 652's??
I don't really think that's a fair statement really, but thats beside the point.
Harry - if you find a whole engine it will fit without modifying the body. This AZU I saw at the weekend had one fitted - it would happily do 140k, which given its a van is pretty damn impressive:
Note the block in the top left corner, the chappy said that the computery bit is the hardest thing to get working. It does magic stuff with ignition and... stuff...
His only mod was putting the light bar on upside down to clear the front of the engine - I thought that was clever.
Also, look up Team Biodeuche on Facebook - they were at Snet and will be racing at Spa. The engine in car 66 is a 2cv block with Visa pistons/barells and visa heads. It develops 16:1 compression and 64bhp at 8000rpm :shock: Enough power for you? :lol:
September 29th, 2011, 12:41 am
Post Re: 652's??
Also, that AZU is running 400mm rims, apparently that helps maintain a higher gear ratio, a bit like Joolz with his 80 profile tyres. Oh and Team Biodeuche use a standard 2cv box.
September 29th, 2011, 12:44 am
Post Re: 652's??
Yes for now :lol:
Thank you Sam.
Low and Loud!
September 29th, 2011, 12:02 pm
Post Re: 652's??
Mind you,
you'd need to run almost pure ethanol to cope with that compression ratio, plus convert the engine to fuel injection.
< http://www.bioperformanceuk.com/bioethanol_answers.php >
Yes for now :lol:
Thank you Sam.
September 29th, 2011, 12:58 pm
