View unanswered posts | View active topics It is currently June 19th, 2026, 3:51 am
Reply to topic  [ 148 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 15  Next
 A 4x4 is (re)born
Post Re: A 4x4 is (re)born
That is very clever thinking. Well done getting out of trouble being stranded on the road. You can come raiding with us any time no worries. :mrgreen:
Glad you got home, see you some other time
Cheers
Viking
August 8th, 2011, 12:42 am
That's a very unusual 'injury'. But don't worry, you can always rely on the french to be helpful.... :lol:
August 8th, 2011, 1:26 am
spot the 7 differences!!!!!
August 13th, 2011, 7:09 pm
Hi Lpgo,
The air springs,which vehicle are they from?
viewtopic.php?f=19&t=2301&hilit=re+born&start=70
Cheers
Peter
October 2nd, 2011, 1:27 pm
subarupete wrote:
Hi Lpgo,
Cheers
Peter
Well I'm still in doubt about the airsprings these are comming from a big Ford suburban or something like that but they are way to big (my opinion) 180 mm
diameter infront and 150 mm rear + the stroke is to small only 3 inch so I am not going to use them.... 100 euro and they are yours.
There are 2 optionsleft:
using cilinders like crazy belg car diameter 100mm stroke 5 inch or
airshocks http://www.ridetech.com/store/index.php ... ct_id=7547
I think it is going to be the cilinders diameter 100mm both front and rear fixed at 1 point at the chassis and then a long pushrod.
BTW. At the moment I'm out of order , a car pushed me from the road going to my work on my bicycle.......... :? :? :? :?
It wasn't my fault but on a bike your'e always screwed..... :( :( :(
October 2nd, 2011, 8:23 pm
Hi Lpgo,
Thanks for the info.
Will send pics of my rear suspension when is more complete
October 2nd, 2011, 10:16 pm
subarupete wrote:
Hi Lpgo,
How will I ever learn decent English when you write like this?? :lol:
October 2nd, 2011, 10:25 pm
Maybe Crazy Belg car used these
http://www.airbagit.com/product-p/cyl-04-cylfrnta.htm
October 4th, 2011, 9:51 pm
subarupete wrote:
I gave crazy Belge a pm. the day before yesterday, he p.m.-med :?: me back that he will look if they are still available and at which price....... otherwise it will be the ones you mentioned..... They have also 3.5 inch with 13 inch stroke
but I think they are not strong enough.... Are you interested too in in airsuspension in your'e monster....... will be great fun...
I think if "we" fit cylinders we have to fit expanding tanks too because the cylinders are to small the airpressure will be to high so the suspension will be to hard. Something like this
http://www.airbagit.com/SearchResults.a ... ccumulater
October 4th, 2011, 11:26 pm
Bit more progress.....
Inverted Spring and Shocks. Better ground clearance but the C of G raised a bit.
Tried inverting the rear arms (swapped over L->R and R->L), but drive-shaft fouls the arm.
So I have fabricated my own mounts, with the arms the correct way up.
For the moment have left the brackets for the standard suspension in place.
Future Upgrade to allow height adjusment.
Annotation shows room for either Air or Hydraulic suspension??
However "Air suspension" with mud and water may not be a good mix.
October 5th, 2011, 4:47 pm
