View unanswered posts | View active topics It is currently May 2nd, 2026, 12:49 am
Reply to topic  [ 26 posts ]  Go to page 1, 2, 3  Next
 Charge Lamp LED
Post Charge Lamp LED
Brightspark on Ebay can supply an LED charge lamp to your bespoke requirement.
http://cgi.ebay.co.uk/12v-LED-Battery-M ... 1622wt_907
If you email and request for a 5mm LED with the following config.
Cost £11.75
Red flash > 15.0v (Over charging)
No output > 13.0v (Normal charging)
Orange > 12.4v Normal battery, (engine not running)
Orange Flash < 12.4 v Not Charging
The 5mm LED will be a snug fit in the 2CV Lens
Connections......12v (switched) and an earth
Lens with cut down rear body
June 7th, 2011, 4:02 pm
Post Re: Charge Lamp LED
NIce find...
June 8th, 2011, 11:28 am
I have emailed them to see if he can make a....
key on one amber light then with engine running amber goes off at 13.9v to be replaced with green which inturn goes off to be replaced with red above 14.7 volts
June 8th, 2011, 7:43 pm
why?
why would you want a light always on? the original one looks fine to me- flashes amber at you when the fan falls off goes orange if you stall and don't notice and flashes red when the reg not working
June 8th, 2011, 8:30 pm
Sean wrote:
why? why would you want a light always on?
For the Picadilly Circus dash look :D
June 8th, 2011, 10:38 pm
For the Picadilly Circus look you'll need at least seven, all calibrated a bit differently. There again you could string up fairy lights for quite a bit less.
June 13th, 2011, 10:45 pm
emailed him to see if he will do what you have sggested
i like the idea
maybe green for when normal charging is commencing though???????????????????????
June 15th, 2011, 11:17 pm
ordered mine today,
asked to have your config except when normal charing is commencing to have green not no output
June 17th, 2011, 12:24 am
Like this....neat !
Think I am now off to eBay !!
Great find !
June 18th, 2011, 8:08 am
Jameswallace wrote:
ordered mine today,
It will be a distraction, Ive got 2w bulbs in the high beam warning lights and still it catches the eye.
cant think of any car that has a warning telltale ON in the normal/safe mode
June 18th, 2011, 8:31 am
Users browsing this forum: No registered users and 107 guests
