View unanswered posts | View active topics It is currently November 19th, 2025, 5:54 pm
Reply to topic  [ 3 posts ]
 Removing pedal box/master cylinder
Post Removing pedal box/master cylinder
Just a quick one, I'm in the middle of stripping the 2CV, and have come to the pedal box. I've undone the two 14mm bolts holding it to the bulkhead, now does the master cylinder detach from the pedal box, or do I have to take the reservoir off the cylinder and push the whole lot through the hole? The box appears to be held onto the cylinder with flange ended bushes, but maybe I'm having a stupid moment..
June 7th, 2011, 7:27 pm
Post Re: Removing pedal box/master cylinder
Pete
yes pull the master reservoir off by pulling it to one side and itll pop out the seals
then the master and the full pedal assembly pulls into the car you have to rock it one way then the other to get the front port through the gap.
June 7th, 2011, 7:35 pm
Aha! Nice one, thanks! I was getting hungry so abandoned it, but will have the mother' off tomorrow.
June 7th, 2011, 8:43 pm
Users browsing this forum: No registered users and 19 guests
