View unanswered posts | View active topics It is currently February 3rd, 2026, 10:18 pm
Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3  Next
 1981 Drum brake charleston
Post Re: 1981 Drum brake charleston
Thought I'd update this thread with some progress - especially as work has recommenced after a bit of a break.
Further poking revealed just how rotten the underside is (including chassis):
So new floors/sills bulkhead welded in, shell off and turned over to repair the rear sections
Finally - started applying a good coating of zinc primer and underseal with the body ready to go back on
The old chassis was chopped up and an original-pattern Citroen chassis built up ready to take the shell:
This was all a couple of months ago. The Charlie was then loosey reassambled to be towed to my folks to live there while we moved house:
It was in good company ;-)
I've finally saved up/got around to recommencing work now I have a garage/driveway to work in again. New sweeps and windscreen surround sections have been purchased to tackle the next big jobs. I've never attempted either so it will be quite interesting to see how well (or badly) it goes.
Watch this space for further updates!
1979 2cv6 (Evie)
1983 Beachcomber (Mavis)
1991 AXGT Mk1
2008 C5 2.0 HDi VTR+
June 1st, 2011, 3:10 pm
Great work, Will! You really do crack on. :)
June 1st, 2011, 4:44 pm
Thats fantastic....well done....makes me feel like getting on with my own project....good stuff...keep up the good work
June 1st, 2011, 5:24 pm
Good job!!
I also started work on my AZU 1974 again, after 5 months break.
Keep posting
June 1st, 2011, 6:16 pm
Nice work!
June 1st, 2011, 11:44 pm
Update: Have had a bit of a weldathon and cracked on:
The rear panel was worse than I thought (no surprise there then)
Not a lot left of these!
Measure twice, cut once!
Checking the quarter window fits before welding:
Chopped out the rear panel grot. Can't afford a whole new panel so I'll repair it somehow.
Repairs to edge of boot floor
Window fits here too. Phew!
With the sweeps done I turned my attention to this:
It didn't put up much resistance...
Luckily the metal underneath is pretty good apart form the crossmember under the windscreen which I'll repair.
Better check the screen fits at this stage!
Panel in place, with only tidying up left to do.
On the whole, the windscreen panel wasn't too much of a chore to do once the old one was off (a mixture of drilling spot welds and cutting rusty metal). The sweeps weren't too bad either, a bit of jiggling to get them to sit right but not as painful as I'd feared.
It is getting there slowly!
1979 2cv6 (Evie)
1991 AXGT Mk1
June 17th, 2011, 11:21 pm
Looks very good from here Will. Have you got any pics of the inner rear wing, did you have to add any metal along the top of it?
I've never understood how to fit new panels, when it's always the seams that are rusted, i.e. an inch from the edge of both panels.
June 18th, 2011, 1:55 am
Blimey Will, that's some proper rot.
Beautiful.
June 18th, 2011, 9:30 am
The repair sections have a reasonably generous flange so I had enough to join the inner wings to, even after trimming the rust away. Ok, there was one bit that I had 'persuade'to join together and another bit that was maybe more seam sealer than metal but on the whole it was pretty ok.
1979 2cv6 (Evie)
1991 AXGT Mk1
June 18th, 2011, 11:47 am
Update - Charleston Haz MOT! All complete bar a few little bits to sort:
Glad it is finished, it's been a challenging project but another one saved! Now, whether to put it up for sale or not....
1979 2cv6 (Evie)
1991 AXGT Mk1
September 9th, 2011, 11:42 am
Users browsing this forum: No registered users and 610 guests
