View unanswered posts | View active topics It is currently June 29th, 2025, 4:24 pm
Reply to topic  [ 587 posts ]  Go to page Previous  1 ... 36, 37, 38, 39, 40, 41, 42 ... 59  Next
How does it sleep in your van ?? Better than in your own bed?
May 23rd, 2011, 6:02 pm
I slept really well :D the bed is really comfy! I didn't get dripped on either - I left the vent flap open so there was fresh air, it was really nice!
May 23rd, 2011, 6:16 pm
Do you fill a draw with water and use it to do your teeth???
May 23rd, 2011, 10:45 pm
Having had an extremely comfortable night in the van I realised two things. Firstly, in the morning it was extremely bright. Secondly, in the evening it was extremely dark.
Mummy Fieldhouse, buoyed by the success of the mattresses, kindly made some curtains :)
There'll be one to cover the windscreen too I believe.
I meanwhile sorted some lights. I found a constant live wire in the back that is clearly meant for an interior light so will use that as the feed. I've mounted some (ex 240v) halogen spots on the rear woodwork that supports the cupboards at the back.
These have been converted to 12V and I've ordered LED cluster bulbs to save power.
I'm rather pleased with the implementation of these lights. I've mounted them onto a hinge, which I recessed into the mount using a belt sander. If you've never used a belt sander BUY ONE they're so useful and so much fun!
The hinge allows the lights to flip down. They're held in place with a catch.
This means that they can either light the cabin, or when dining behind the van, flip down to illuminate outside.
Onto problems!
I've stopped the oil leaking from the gasket between the crank case and the oil filler, but its still flicking up over the right hand side from somewhere, although I'm hoping this is just 'left overs.'
Apart from the fact the drivers door handle fell off last night, and since being re-connected refuses to lock, the main issue was high beam just not working (it did last week!).
It was pointed out to me that this could be caused by over charging. So I duly checked the charge rate - which turned out to be 16v when revving!!!
I tried 2 voltage regulators but neither made a difference. After a few calls to Daras Rich I installed an olde style curly wire twin terminal voltage regulator (the type that you can adjust). This worked a treat and we 'tuned' it down so when revving it's now charging at 14v - much safer!
Incidentally it turns out the alternator is a very rare type unique to 350s only fitted between '66 and '67 so I'm glad its not at fault!
After changing (and testing) the light bulbs high beam still didnt work, but a little fiddling with connectors in the headlight loom and...
... it quite literally came off in my hand :roll:
So out with the crimps and electrical tape. Ideally it need a new headlamp loom.
The trials and tribulations of an old 2cv!
May 24th, 2011, 7:02 pm
it is about time my AZU project gets finished, so I can sleep in the van and won't be disturbed by the snoring of my Missus :lol: :lol: :lol:
May 24th, 2011, 9:34 pm
if you ever need any of the terminals ~(spade or such ) that they used on a 2cv, let me know, ive just revently cut up my burnt out loom and cut all the connectors off just incase
May 24th, 2011, 10:24 pm
:lol: Get it on the road - 2011 is the year of the van 8-)
Cheers James, I shall bare that in mind.
Curtains are done :)
May 24th, 2011, 11:25 pm
Please tell me these spelling errors are meant ironically.
May 24th, 2011, 11:29 pm
May 24th, 2011, 11:30 pm
Vin plate looks well trimmed. Are you sure it's original to that shell?
And 'Paint code' in english. Methinks that was added by a previous tinkerer.
John Jordan
May 24th, 2011, 11:40 pm
