View unanswered posts | View active topics It is currently May 1st, 2026, 8:30 pm
Reply to topic  [ 10 posts ]
 Hot wired
Post Hot wired
2cv arriving with head light and charging problems. No wonder, regulator and multi plug burned, fuse box burned, some wires running to dash and head light bar burned, light switch burned. Looked in my ‘’original’’ English work manual for correct fuse sizes but nothing. Can anyone help please. The fuse box has 3 fuses only. I should add that it was not the common rubbing through on the air filter housing. What happened I don't know.
Cheers
Viking
May 19th, 2011, 8:58 pm
Post Re: Hot wired
Blue spot 16A
red spot 10A
yellow spot 10A
May 19th, 2011, 9:29 pm
Post Re: Hot wired
Sean wrote:
Blue spot 16A
red spot 10A
yellow spot 10A
Good man thank you
May 19th, 2011, 9:42 pm
Post Re: Hot wired
Voltage regulator fell off and shorted out?
Must have had a fuse with much too high a rating to melt the plastic of the holder, maybe wrapped in aluminium foil or even stuck a nail in... :o
May 19th, 2011, 11:11 pm
Post Re: Hot wired
As its the blue circuit thats taken the hit thats: wiper motor,voltmeter,fuel guage,indicators and alternator field./voltage reg
all the usual suspects then-but as Ken says the burnt Reg points to regulator on the crossbox symptoms
and youll have another sparky moment if you keep putting your tools on top of the battery :lol:
(so many burnt spanners :lol: :lol: )
May 20th, 2011, 10:18 am
Post Re: Hot wired
Some of wires running next to the burnt wires are cooked too.
May 20th, 2011, 1:24 pm
Post Re: Hot wired
Collateral damage?
Once the fox gets in amongst the chooks, even those which survive will have lost a few feathers... :lol:
May 20th, 2011, 2:34 pm
Post Re: Hot wired
When I burnt my loom out instead of fiddling I replaced (thanks again RT) with another !!!
May 21st, 2011, 12:07 pm
Post Re: Hot wired
Yes that's a modern thing but I'm a mechanic so I repair when possible. Don't want to join the queue being ''parts replacement junkie'' :mrgreen:
May 21st, 2011, 1:04 pm
Post Re: Hot wired
I was all for repairing it but I needs the car, in a rush and it was quicker. So that's what I did
May 22nd, 2011, 12:38 am
