View unanswered posts | View active topics It is currently May 8th, 2026, 6:18 am
Reply to topic  [ 587 posts ]  Go to page Previous  1 ... 35, 36, 37, 38, 39, 40, 41 ... 59  Next
I thought Adrian said bigger ones, can't remember. It's weird that the gearbox that's in their now - the bulkhead's been smacked to allow enough clearance for the gear change, which has also been cut and welded for some reason.
May 21st, 2011, 9:53 am
Sounds like an ami box then, that'd have a different linkage to a 2cv.
May 21st, 2011, 10:13 am
Ami engine, Ami box, makes sense I guess.That could also explain why I barely get into 4th gear, its a big leap.
May 21st, 2011, 1:16 pm
It was the same in my old 6, its nice though when you're on the autoroute cruising at 130kmh.
May 21st, 2011, 6:06 pm
That might be optimistic for the van
May 21st, 2011, 6:32 pm
Highest reading for Hugo was 110kph, which is around 68mph - that was somewhere in northern France, sometime in 2003 - me, the girlfriend, and a load of camping gear - I wouldn't exactly call it 'cruising' though...
May 21st, 2011, 6:38 pm
Cruised happily at 60mph today :) much smoother at 60 than 50 for some reason. Took a while to get there but we did it in the end!
There's been a dreadful rattling from the back for a while. Turned out the van flat bed wasn't actually attached to the van body at the forward end :roll:
So got my Dad's rivet gun out. The rivets are ex-RAF so they should be up to the job.
I put plenty of underseal under it to keep water from settling.
I was pretty pleased with the result and it certainly doesn't rattle anymore :)
Mummy Fildhouse kindly spent the day stitching up the covers for the mattresses :)
I think I've finally sorted the oil leak. I made a gasket for the oil filler and it seems to have stopped leaking. Finally.
All round, a successful day
May 22nd, 2011, 10:53 pm
How very French! :)
May 22nd, 2011, 11:14 pm
How very French! :)
and very effective :)
Thought I should test the bed so tonight I'll be sleeping in the van!
Wish me luck!
May 23rd, 2011, 12:06 am
Don't forget to oil suspension
May 23rd, 2011, 7:44 am
