Oil - Everywhere. Smoke too!
 Re: Oil - Everywhere. Smoke too!
Jameswallace wrote: as far as o lmpw (probably wrong ) when the engine "breaths" the flap inside lets the air out or in, presumably out, so it spits oil as it blows out waiting my dressing down for being being wrong  spot on lad as the pistons go down they have to displace 602cc of oily fumey air as they rise the one way valve closes and so a lower pressure exists inside the engine helping to suck the oil in from the holes in the engine like the cam shaft nose in the points box and either end of the crank
| May 17th, 2011, 11:15 pm |
Jonathan
Joined: January 1st, 2009, 7:37 pm Posts: 4709 Location: Disunited Kingdom
And W is a vowel in Welsh, along with Y, so Welsh has more vowels than English.
| May 17th, 2011, 11:16 pm |
samfieldhouse
Sean wrote: Jameswallace wrote: as far as o lmpw (probably wrong ) when the engine "breaths" the flap inside lets the air out or in, presumably out, so it spits oil as it blows out waiting my dressing down for being being wrong  spot on lad as the pistons go down they have to displace 602cc of oily fumey air as they rise the one way valve closes and so a lower pressure exists inside the engine helping to suck the oil in from the holes in the engine like the cam shaft nose in the points box and either end of the crank So if I tube the breather into a bottle do I need to make sure air can get in and out too?
| May 17th, 2011, 11:19 pm |
it will as long as you don't seal it up
| May 17th, 2011, 11:23 pm |
toomany2cvs
samfieldhouse wrote: The oil feed pipe bit is worrying - you can't get M4 oil feed pipes! The head feed pipes were replaced with good ones at the Dutch world meeting ('97, mebbe 1500-2000 miles ago...), after one of the brazed-back-on unions to the big banjos either side of the crank fell off. It didn't do that. What it DID do was completely cover the back of the van with oil.
| May 17th, 2011, 11:37 pm |
samfieldhouse
The back of the van?
| May 17th, 2011, 11:44 pm |
where all the crap ends up being blown/sucked
Not IN the back of the van - on the doors
| May 17th, 2011, 11:46 pm |
twofifty AZU
samfieldhouse wrote: ben wrote: Instant rust preventer. What is that comedy air filter, should the breather be connected back to the carb via the airfilter somehow . There's no air box in existance for an AK350 with an Ami 6 engine  The ami 6 one is just plain wrong and nothing else will fit between the bonnet and the frankly massive carb! Taking a pipe either down to road level or into a box will be the way forward, Box would be more eco and sociable  Yes there is, this has an Ami 6 engine
| May 17th, 2011, 11:47 pm |
samfieldhouse
Oooo where did you get that, what's it off? Is that on a 40 carb?
| May 17th, 2011, 11:54 pm |
Jonathan
That blue is a lovely shade. What's the name of it, twofiddy?
| May 17th, 2011, 11:55 pm |
Users browsing this forum: No registered users and 14 guests |
